planing green boards?
Forum topic by fishinmonkey posted 01-11-2012 08:50 PM 780 views 0 times favorited 2 replies Add to Favorites Watch
View fishinmonkey's profile
fishinmonkey
9 posts in 2291 days
01-11-2012 08:50 PM
Topic tags/keywords: planer green lumber
This summer I cut down a couple of spindly wild cherry trees in my back yard and bucked most of it into stovewood lengths, but left a few larger diameter pieces longer. And then, as luck would have it, was gifted a used Grizzly G0555 band saw with the riser block kit. I figured I could resaw these larger pieced into boards and dry them for future use in jewelry boxes and similar small projects.
I left the logs in the open air and am finally getting around to cutting them up now. Because of our winter rain, they are still fairly wet. I’ve never used a band saw before, and am having a bit of trouble getting the hang of following the saw’s drift, so the boards are coming out a bit on the wavy side. Not a big deal, seeing as anything I can’t use I can burn.
I just picked up a 13” lunchbox plainer and thought that maybe I could build a clamping jig to hold the boards steady and then run them through the plainer to even their faces out. I did a bit of research on the web, and it sounds like at least some major manufactures of dimensional stock for the cabinetry industry green plane their stock. The benefits, as I understand it, include ensuring even board thickness, so stacks of drying boards sticker better, and more even drying rate (possibly slightly quicker drying times) because of the even surface.
The downside I would worry about would be introducing more sap and moisture into my planer than it is designed for, leading to rust and reduced tool life.
So, does anyone green plane their stock. Would I be ok if I lightly oil the plane’s blades before use (as per manufacture’s recommendation, and then wipe down all reachable surfaces when I’m finished. Any other consideration I should think about.
Thanks is advanced for the help.
-- I like to cut wood apart using various power tools and then screw and/or glue the pieces back together agian. It passes the time.
2 replies so far
View peterrum's profile
peterrum
153 posts in 2642 days
#1 posted 01-16-2012 12:04 PM
Cutting green is fine but I would not plane it until it has dried. The planer isnt designed to do that and you would end up having to do it again after it is dried as the dimensions will change. I mill my stock to a minimum of 5/4 and it is at least a year before it sees the planer.
-- Carpe Diem
View Bill White's profile
Bill White
4901 posts in 3924 days
#2 posted 01-16-2012 07:07 PM
Peterrum is correct. Also, the right blade for green wood (plenty of kerf) will help on the cutting. Dimensioning green wood is a waste of time.
Bill
-- bill@magraphics.us
