| Forum topic by Lenny | posted 496 days ago | 1171 views | 0 times favorited | 21 replies | ![]() |
496 days ago |
I submitted a question to the Q and A section of Woodworker’s Journal magazine and they opted to answer it in their “e-zine”. For those that don’t choose to open the link, my question essentially was: “What is protocol on maximum lengths of stock to SAFELY push through one’s jointer. To their credit, they opted to address both minimum and maximum lengths. Here’s the link: “Jointer”: http://www.woodworkersjournal.com/Ezine/Public/QA.aspx. I would be interested in LJ responses to my question and the responses offered by WWJ. I often buy 8’ lengths of lumber. Are they safe to push through a 6” jointer with say a bed that is 46” long (my Delta)? If the board is 8” wide and 8’ long is it safe to edge joint it? Do you have any standard practices relative to this topic or do you just joint what needs to be jointed? The safety issue is foremost but I guess at some point, the length also begins to affect the precision of the cut. If the board loses contact at a point or two along the length you don’t have a uniformly flat edge or face. -- On the eighth day God was back in His woodworking shop! Lenny, East Providence, RI |
21 replies so far
#1 posted 496 days ago |
Well, I have pushed 8ft 8/4 Ash through mine when building my workbench laminate top without issue. My jointer bed is 75in though. You could always set up roller stands before and after to catch/support these monsters. IMO, that would be the best way to prep for long jointer pieces. BTW, I have managed to joint a 9in wide 8/4 on my 8in jointer by taking very small cuts and horizontally rotating the piece after EVERY pass. BE WARNED: This requires removing the cutter guard to do this, so do this at your OWN risk. I then take my 18in foreplane and smooth out the minor difference on the last pass before running the board through my lunchbox planer. I had VERY LITTLE waste doing it this way. -- HorizontalMike -- "Woodpeckers understand..." |
#2 posted 496 days ago |
You can joint an 8’ board on a 6” jointer, but there is seldom I find a 78” level the most useful tool for surfacing wood in that Milling wood is a really creative activity and there are a lot of nuanced See, a board will have bulges and stuff in the face and sometimes |
#3 posted 496 days ago |
I’ve tried to joint 8ft boards for a workbench on my 55” long jointer; was extremily difficult and I didn’t really have a satisfactory result. Wood that I know I’m going to cut into smaller pieces for a project, I roughly crosscut it before jointing it, much easier to handle and I have to remove less wood than if I used a long piece. As for minimums…anything less than about 6” I get pretty nervous about… -- Rob, Sault Ste. Marie, Ontario |
#4 posted 496 days ago |
Anyway, you can make an outfeed table, as I have done before, |
#5 posted 496 days ago |
For any stock over 5 feet long, I make sure to use an outfeed roller. I usually layout the parts on my stock, and cut the parts to rough length before jointing. A dining table is one notable exception, where you need boards 6-7 feet long. Even then, the boards on extension tables run widthwise and are usually no longer than 4 feet. -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
#6 posted 496 days ago |
All are points well taken. The in and/or outfeed rollers make great sense and a custom outfeed table is a nice idea too. Thanks for the input. -- On the eighth day God was back in His woodworking shop! Lenny, East Providence, RI |
#7 posted 496 days ago |
This may be seen as a cop out, but I have been using a glue line rip blade on the TS for long pieces. Good results and no fear. Glue ups have been very good. So far….......... -- bill@magraphics.us |
#8 posted 496 days ago |
I have jointed long board but it is difficult when you are alone. In school we were taught to get a buddy to help “tail off” the board but these days I am alone more often. in-feed and out-feed tables or rollers would be the answer and those could make the process limitless I suppose…...if you could get them level. The shortest board that should be jointed is 12 inches according to the safety rules in most jointer manuals. I have had one board jerked from my hands in a jointer and it was scary. I was not remotely injured but it was a thin short board so I started believing those owner’s manuals. |
#9 posted 496 days ago |
Painting a line on the top of the fence for the minimum length is a good idea. I think I may do that on my jointer and on my planer cart. |
#10 posted 496 days ago |
Lenny, Thanks for this question. I’m just about to begin a new project that requires to join several 55” boards for the side panels. My jointer is a 8 inch helical head grizzly, with a 75 inch bed. Using the in-feed and out-feed rollers sounds like the smartest way to go. -- -Gerry, Hereford, AZ ” A really good woodworker knows how the hide his / her mistakes.” |
#11 posted 496 days ago |
Bill White I don’t view it as a cop out at all. If you are getting nice square and uniform cuts, suitable for gluing, that’s great. I wonder though, how you make the first cut? If using rough lumber, a square edge is usually desired before using the table saw. Thanks again to all for the comments. Hi Gerry. Happy New Year and amen to your last comment. -- On the eighth day God was back in His woodworking shop! Lenny, East Providence, RI |
#12 posted 496 days ago |
Good question , Lenny , and some good answers as well : ) -- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did. |
#13 posted 496 days ago |
I agree with Manitario. One is much more efficient with wood use if rough crosscutting is done early in the milling process. I have a 6” helical Powermatic and I made several simple jointing jigs for safety. Face jointing a two- to three-foot pieces is both safe and wood-efficient. -- Paul, Clinton, NC |
#14 posted 495 days ago |
Hey Lenny great topic you have going on here with plenty of neat ideas from fellow jocks. I would like to chime in on the view of B.White, I don’t have a jointer in my shop due to space issues as well and use my T.S. as my jointer for years. The first cut is done by using a straight edge taxi on the desired board which ride along the fence this will duplicate the straight edge to the opposite of the board. If the board has been plane flat two sided face tape works great if not you may have to tack the straightedge to the stock being edge . Ever since the early 80’s I’ve used ridge carbide TS 2000 blade on my saw which produces great glue joints. I also am a great advocate of the grip tight system for TS fence. These magnetic holder keep your board steady against the fence during ripping leaving a burn free edge on the stock which help vastly on producing the clean edge for gluing. For shorter piece I go to my reliable hand planes which allow me to listen to the radio or music in the shop. Final I use my Incra super system with the wonder fence which produce flawless glue joints as well, I use this for 3’ and less dimensions. These are just some more idea to toss around hope all is well and snow free my friend take care…Wilson |
#15 posted 495 days ago |
Thanks for the comments Len and Paul. Hi Wilson. I have seen the technique of “taxi-ing” a board as you mention and can see how it would provide a straight edge which could then be placed against the fence to get a straight and parallel cut on the other edge. I too have used my Incra LS Positioner as a jointer for pieces that are router bit height and not too long. However, let me play devil’s advocate for a minute regarding your statement: “If the board has been planed flat”. Generally with rough lumber, the first step in milling is jointing a face-side flat. If you go directly to the planer and send one side through, supposedly the planer will simply make a cut parallel to the bottom side. If it is not flat (horizontal), the cut is not flat. Is this not true? -- On the eighth day God was back in His woodworking shop! Lenny, East Providence, RI |
| Forum | Topics |
Woodworking Skill Share
8792 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
79 |
Finishing
1531 |
3547 |
15771 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2839 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6157 |
