Scrollsaw Blades Look Like Fishhooks????
Forum topic by jerrells posted 01-11-2012 04:29 PM 1497 views 0 times favorited 8 replies Add to Favorites Watch
View jerrells's profile
918 posts in 2820 days
01-11-2012 04:29 PM
Topic tags/keywords: question scroll saw scrollworking
I just purchased a used DeWalt Scrollsaw 788 Type 1 and every blade I put in the upper clamp does this to them. I have been using two types of blades, Olson and Seyco. Ray at Seyco suggested clamping pressure (amount I tighten the screw) but I have tried less and less. I still get the look of a fish hook on the blade after a few uses. What do I need to do?????
-- Just learning the craft my Lord and Savior Jesus Christ practiced.
8 replies so far
View StumpyNubs's profile
7576 posts in 2736 days
#1 posted 01-11-2012 05:22 PM
Buy some fish hooks and see if they bend into blades…
(World's best woodworking show is now online!)
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications:
View mtenterprises's profile
933 posts in 2629 days
#2 posted 01-11-2012 05:41 PM
I would try tighter, the blade should PING when plucked. Keep tightening untill you get that PING then try running it.
-- See pictures on Flickr - And visit my Facebook page -
View MrsN's profile
984 posts in 3462 days
#3 posted 01-11-2012 05:52 PM
there should be a set screw on the other side of the thumb screw that you use to tighten the blade. adjust the set screw so that it will center the blade in the holder.
View Elizabeth's profile
817 posts in 3079 days
#4 posted 01-11-2012 06:14 PM
I have a DW 788 and it doesn’t do that to my blade – the blades are still straight when they are removed. It looks like whatever mechanical method is being used to hold onto the blade (I haven’t looked at mine closely) is not in alignment on the two sides. It should be pinching closed on the blade evenly on both sides.
Take a close look with a flashlight and see if you can work out a) what is misaligned b) whether you can get it back into alignment. If not, maybe DeWalt customer service can help – I don’t know how helpful they are as a general rule.
View MrsN's profile
#5 posted 01-11-2012 06:54 PM
I went out and took a picture of the set screw that you ne
ed to adjust. It is some sortvof a hex screw but I didn’t measure it.
I also discovered that I need to really adjust the screw on one of my saws.
View Jim Finn's profile
Jim Finn
2641 posts in 2858 days
#6 posted 01-11-2012 07:16 PM
MrsN has the answer! Try it.
#7 posted 01-11-2012 07:57 PM
YES – I think that Mrs. N hasw answered it. ALSO, I need to start using less torque (tighting the screw) on the blade. On my old saw I had to really clamp down to make it hold.
View Keith Fenton's profile
Keith Fenton
328 posts in 2856 days
#8 posted 01-11-2012 08:42 PM
If you find you are needing to put a lot of torque you can try cleaning off the tips of the thumbscrews and set screws. Sometimes they get oily residue on them. Also over time the screws may get a little rounded on the tip and you may need to sand them flat again. I always clean my blade tips off with paint thinner when I first put them in to remove any oil they may have on them which seems to help quite a bit for me.
-- Scroll saw patterns @
