Getting a straight edge on rough planks
Forum topic by revanson11 posted 01-11-2012 04:32 AM 3226 views 0 times favorited 7 replies Add to Favorites Watch
View revanson11's profile
revanson11
111 posts in 2534 days
01-11-2012 04:32 AM
Hi, I’m a new member and a novice woodworker. A while back I was given about 150 board feet of red oak boards. I ran them through my planer and now they are nice and smooth and range in width from 3” to 10” and are about 8’ long. My problem is that none of the boards have a straight edge on them and I was hoping that someone here could give me advice about how to go about achieving that. Thanks in advance.
-- Randy, Central MN
7 replies so far
View HerbC's profile
HerbC
1790 posts in 3061 days
#1 posted 01-11-2012 04:50 AM
Use a jig made of a 10” wide, 8’ long piece of plywood or mdf. Attach the oak boards (one at a time) to the jig using a couple of screws, aligning the edge of the oak board to overhang the jig board. Use the jig as a guide against the rip fence of your table saw and rip the edge straight. Once you have one edge straight, remove the boad from the jig and use the table saw to rip to it to width, straightening the other side.
Good Luck!
Be Carefull!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View ajosephg's profile
ajosephg
1880 posts in 3762 days
#2 posted 01-11-2012 04:54 AM
I take a piece of plywood equal or greater than the length and less than the width of the board to be straight edged and screw it to the work piece (one screw on each end) with the plywood offset from the edge of the work piece.
-- Joe
View Loren's profile
10477 posts in 3849 days
#3 posted 01-11-2012 04:56 AM
I prefer to bandsaw a straight edge, following the clearest line to a
straight-grained board. Then you can rip the other side parallel
on the table saw. More waste this way, but you get nice boards.
The other thing is that you very seldom need an 8’ long straight
board, so I’d say pick your projects and lay out the parts on the
boards so the grain is most pleasing, then crosscut, bandsaw the
parts 1/4” oversized and so forth.
View Jim Finn's profile
Jim Finn
2687 posts in 3123 days
#4 posted 01-11-2012 10:37 PM
”.......The other thing is that you very seldom need an 8’ long straight
board….......”
I agree. I wold cut them to approximate length and run one edge over my jointer to get it straight, then move on to the table saw.
-- No PHD just a DD214 Website> craftingcouple.com
View ETwoodworks's profile
ETwoodworks
92 posts in 2894 days
#5 posted 01-11-2012 10:50 PM
I don’t have a bandsaw so I just snap a chalk line across it and cut that with the circular saw. then you can rip the other edge on the table saw.
-- Building quality in a throw away world.
View pmayer's profile
pmayer
1032 posts in 3267 days
#6 posted 01-11-2012 11:01 PM
I use the band saw for this as well. Quick and simple. A jig like this one used with a circular saw would work as well: http://www.wwgoa.com/articles/one-great-tip/shop-made-circular-saw-guide/
revanson11
#7 posted 01-17-2012 01:07 AM
Many thanks to all who replied to my posting. I now know how to proceed. You’re all great.
