How to tighten DP chuck w/o key?
Forum topic by JohnEinNJ posted 01-11-2012 01:18 AM 1850 views 0 times favorited 4 replies Add to Favorites Watch
View JohnEinNJ's profile
JohnEinNJ
94 posts in 2344 days
01-11-2012 01:18 AM
Topic tags/keywords: drill press
I inherited an old drill press with a Ridgid chuck and no key. The chuck is no longer manufactured, and I’ve tried a “universal” key as well as a Jacobs key with the same size pilot (1/4”): no cigar. What’s the best way to tighten the chuck without damaging it? I could do it with big pliers, but that will make nasty scratches in the chuck real quick.
View SASmith               's profile
SASmith
1850 posts in 2984 days
#1 posted 01-11-2012 01:36 AM
Have you considered changing the chuck?
Or find a part number on the chuck so you know what key you need.
-- Scott Smith, Southern Illinois
View Grandpa's profile
Grandpa
3259 posts in 2672 days
#2 posted 01-11-2012 01:45 AM
When all else fails 2 screw drivers will work. Insert a phillips of the correct diameter in the hole on the side of the chuck. Use a common or flat screw driver to inset into the notches and push across the phillips shank. A drill bit will work instead of a phillips and you have a selection of diameters. The common screw driver needs to fit the slots in the chuck as well.
JohnEinNJ
#3 posted 01-11-2012 01:48 AM
@SASmith – thanks for the suggestions. I didn’t want to spring for a chuck, and I also worry about damaging the machine trying to figure out how to get the chuck off. The chuck part number hasn’t helped: I tried calling Ridgid, and also looked in Grainger.
@Grandpa – thanks, I’ll try the screwdriver hack!
View TheDane's profile
TheDane
5423 posts in 3660 days
#4 posted 01-11-2012 02:50 AM
JohnEinNJ—Chucks aren’t necessarily a high dollar item, and removing/reinstalling is easy … see: http://www.youtube.com/watch?v=KbI_7IHAsyw&feature=player_embedded
Just a guess, but it could be a JT33 … similar to a chuck I have for sale ( http://lacrosse.craigslist.org/tls/2734514002.html ).
—Gerry
