Dove Tail Bits
Forum topic by richgreer posted 01-10-2012 11:49 PM 880 views 0 times favorited 4 replies Add to Favorites Watch
View richgreer's profile
richgreer
4541 posts in 2945 days
01-10-2012 11:49 PM
Does anyone know of a technique for easily determining the angle of a dovetail bit?
I have several dovetail bits in my collection. None are labelled. Is there a way to determine the angle without cutting some lumber and measuring the resulting cut? I see no way to measure the angle on the bit itself.
View SnowyRiver's profile
SnowyRiver
51453 posts in 3351 days
#1 posted 01-11-2012 12:02 AM
Rich, wouldnt a digital protractor work?
-- Wayne - Plymouth MN
View PurpLev's profile
PurpLev
8534 posts in 3519 days
#2 posted 01-11-2012 12:03 AM
you could indent the carbide/hss profile into a piece of paper (push it so that it leaves a mark) and measure that. assuming there is some variability to the angles it should be easy enough to determine if it’s 9 or 7 degrees.
View Loren's profile
9760 posts in 3519 days
#3 posted 01-11-2012 12:11 AM
A dial caliper and a little trigonometry will tell you.
View Viktor's profile
Viktor
462 posts in 3289 days
#4 posted 01-11-2012 12:20 AM
A = atan[(b-c)/(2L)]. This is in degrees.
Often dovetail angles expressed as ratio, then it is simply (b-c) : (2L). 1:7 and 1:8 are most common.
