What wood for NYW Dominy Clock?
Forum topic by JohnR posted 51 days ago 84 views 0 times favorited 4 replies Add to Favorites
View JohnR's profile
JohnR
37 posts in 86 days
51 days ago
At some time this summer, I would like to try to build the Dominy Clock shown on the New Yankee Workshop last season. (NYW #0705)
Since the clock is painted, what would you recommend as the wood to be used? At first, I thought about simply using poplar, but am wondering whether a better grade of lumber will make a difference in terms not only of building the clock, but, also, in how well it will hold up over the years.
Thanks for any thoughts you may have.
-- Sola Gratia, John
7762 posts in 210 days
51 days ago
Hi John,
Poplar is a very stable wood so it shouldn’t be any problem. And it is a less expensive wood as well. It easily takes paint and it looks good stained as well.
You can make the clock out of any wood you like. If you want to get adventurous you might want to try a hardwood, such as walnut, oak or cherry, with a natural finish. Any of these should be consistent with the clock style.
Hope this helps.
JohnR
37 posts in 86 days
51 days ago
Scott,
Thanks for the info. I admire your work very much, so your opinions mean alot.
For others, here is the link to the NYW Dominy Clock:
http://www.newyankee.com/getproduct.php?0705
View trifern's profile (online now)
trifern
1822 posts in 156 days
51 days ago
If you are going to paint it, then poplar is your best bet.
-- Depend on the rabbit's foot if you will, but remember it didn't work for the rabbit.
View GaryK's profile
GaryK
8182 posts in 377 days
51 days ago
Poplar
Bookmark And Share This Page
