Warping sheet goods solution
Forum topic by QuickTooth posted 01-10-2012 06:45 AM 1213 views 0 times favorited 6 replies Add to Favorites Watch
View QuickTooth's profile
QuickTooth
8 posts in 2356 days
01-10-2012 06:45 AM
Topic tags/keywords: warp plywood art
This is my first post on this forum and I am hoping to get the advice of from some of the wonderful woodworkers I see on this site. I am more of an artist than a woodworker and could really use some informed opinions.
I have been making 3 dimensional hanging sculptures made from hundreds of small scrap like pieces of painted wood glued to the face of a sheet of plywood. Most of what I made was on a sheet usually 28”x20”. At first I was using plywood but I had a lot of warping issues. I have used OSB recently with better results. And in either case I have had less problems once I was sealing the piece front and back with polyurethane.
Now though, I am being given a great opportunity to make a few much larger versions of these for some public insulation art. These pieces will be on the scale of 3’ x 7’. And while I know I can make the visual side of these I need to be certain that its structural integrity is up to par when hung on a wall for a long term period.
My main concerns are:
1- Prevent Warping from hanging on the wall, and from humidity and such.
2- Must keep the backing as thin as possible. 1/2” is what I have been using currently.
3- Must be able to stand up to having hanging hardware and the weight of itself plus the art on top without things like screws ripping out (my fear on mdf)
Any suggestions as to what choices of sheet material might be better or any modifications to them would be appreciated. Some kind of metal or wood reinforcement maybe?
View peterrum's profile
peterrum
153 posts in 2706 days
#1 posted 01-16-2012 06:04 AM
I would go with Baltic Birch, it is very stable and does not have voids in it which can cause small problems with other plywoods. Some of the “birch” plywood I have seen recently at the big box stores is from China and is absolute junk, lots of twisting and warping in a 4×8 sheet. My advice would be to go to a wood supplier in your area and run your requirements through them. They will be able to help you and provide you with the best advice based on the products they carry or can get in.
Good luck
-- Carpe Diem
View Lee Barker's profile
Lee Barker
2170 posts in 2878 days
#2 posted 01-16-2012 07:21 AM
A frame could help. Using 3/8 (8mm or 9mm) Baltic with a frame could be a good way to go. The frame could help keep it flat and overall your piece would be lighter.
If you want a smooth front, the frame could cover the edges and be flush with the front.
Kindly,
View shipwright's profile
shipwright
7992 posts in 2825 days
#3 posted 01-16-2012 07:25 AM
Do a search on “torsion box”. You could make one with thin skins and not be a lot thicker than plywood and it wouldn’t ever twist or warp.
QuickTooth
#4 posted 01-18-2012 03:45 AM
Thank you so much everyone for your suggestions. I think I will be adding a frame to the back and using birch plywood. Unless I change my mind, which I like to do. I will let you know how it goes when I put it together next week.
View Sawkerf's profile
Sawkerf
1730 posts in 3096 days
#5 posted 01-18-2012 04:58 AM
Your best bet would be 1/2” baltic birch plywood from a for-real cabinet lumber supplier. You want lots of plys for stability and the big box stuff probably doesn’t have enough.
View jcwalleye's profile
jcwalleye
306 posts in 3100 days
#6 posted 01-18-2012 07:35 AM
How about a picture of one of your pieces?
-- Trees, a wonderful gift --Joe--
