Dealing with wood expansion using table extenders.
Forum topic by Brian posted 114 days ago 121 views 0 times favorited 3 replies Add to Favorites
View Brian's profile
Brian
7 posts in 163 days
114 days ago
I’m building a solid 3/4” mahogany table top and was wondering if I should be concerned with the wood expansion when securing the tops to these extenders.
From what I’ve read mahogany appears to be a pretty stable wood type.
Uh…..this only crossed my mind AFTER I’ve already installed the top.
TIA
Extender
-- www.brianpenning.com
View BrianM's profile
BrianM
114 posts in 203 days
114 days ago
Hey Brian,
Not sure if this is what you mean, but when installing the slides in fully closed position it’s a good idea to open them up a just a little before screwing them to the top.
If the wood shrinks that small gap will allow the top to still close tight.
-- There is no such thing as scrap wood!, http://www.saltrivergallery.com
View SPalm's profile
SPalm
702 posts in 333 days
114 days ago
Sounds like you are committed. Did you screw the top to the extenders without glue? It so, it should be alright as the screws can move around in the holes. It you doweled/glued the top to them, it may be a problem. They appear from here to only have about 18 inches of attachment, so this will minimize it some. At least it is not the entire length of the table. I know, just want you want, more excitement.
View GaryK's profile
GaryK
8411 posts in 439 days
113 days ago
I would put some glue on the last 2” (Around the last hole) and then just screws in all the holes.
You shouldn’t have any problem.
Bookmark And Share This Page
