I need plans for a router mortise jig
Forum topic by Don Carrier posted 498 days ago 3473 views 2 times favorited 17 replies Add to Favorites Watch
View Don Carrier's profile
Don Carrier
114 posts in 546 days
498 days ago
Topic tags/keywords: jig router joining
All of the Internet plans I find excel primarily at face frame type joints. I wish to build chairs and need a jig that can handle wide stock and varying angles. I found a couple of jigs on LJ but no plans. I am looking for a basic type jig, I’m not in a production environment.
Anyone care to share plans for a jig?
Thanks
Don
-- Don
17 replies so far
View SASmith               's profile
SASmith
1368 posts in 1156 days
#1 posted 498 days ago
Have you seen these plans?
Here are a few examples of the joints it will cut.
-- Scott Smith, Southern Illinois
View Peter Oxley's profile
Peter Oxley
1423 posts in 2044 days
#2 posted 498 days ago
Peter Oxley
#3 posted 498 days ago
HA! Strong minds think alike I guess, SASmith!
-- http://www.peteroxley.com -- http://north40studios.etsy.com --
SASmith
#4 posted 498 days ago
View Loren's profile
4885 posts in 1817 days
#5 posted 498 days ago
Build a slot mortiser, then add a tilting table to it, like this
fellow did: http://www.woodcentral.com/shots/shot390.shtml
Failing that, a simple cobbled up plunge router jig like those
described in Gary Rogowski’s or Yeung Chan’s joinery books
can be adapted with angled fixtures easily enough.
Another alternative is to adapt Eugene Landon’s methods
using the drill press to chain drill angled chair mortises and
clean them with a chisel. It’s findable in some old Fine Woodworking
magazine and probably a few FWW compilations.
View horky's profile
horky
63 posts in 1100 days
#6 posted 498 days ago
Don, I have had good luck with this one.
http://lumberjocks.com/projects/44089
Don Carrier
#7 posted 498 days ago
Thanks Horky – I’m trying to figure out if thats the best one for chair legs. Seemd most jigs are for thin wood.
-- Don
horky
#8 posted 498 days ago
I made this chair (prototype) and am now making the 6 real ones using this .. legs are about 1.75” square at the widest point. No problems. I can envision a braced L-bracket/platform sliding onto the support table if something wider is needed.
Don Carrier
#9 posted 498 days ago
Very similar to the Chairs I intend to make. Ok you sold me. Are there any plans for the jig available?
-- Don
horky
#10 posted 497 days ago
plans are on the link above. should you have any questions, PM me. Best of luck .. and nice looking chair !!!
View HerbC's profile
HerbC
778 posts in 1029 days
#11 posted 496 days ago
Horky,
I must be blind. I went to the project you linked and can’t find any plans. It’s a nice looking jig and I’d be interested in making one…
Thanks,
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View HorizontalMike's profile
HorizontalMike
4931 posts in 1083 days
#12 posted 496 days ago
I built this last month. Base buildup was Greg Paolini, however I added a lifting mechanism and designed a high efficiency dust collection system for it. I have managed dados of +34in in length with this setup. Have not tried angled mortises yet, but bet they are easily doable.
View tom427cid's profile
tom427cid
299 posts in 640 days
#13 posted 496 days ago
Last year I stumbled upon an Incra morticing attachment for one of their saws. It took a while to figure the basic setup but I will use either a PC690 or a 3450rpm motor from a 3/4hp Shop Fox morticer. Not sure which will work the best.So far total investment is some time and $100.
tom
-- "certified sawdust maker"
View HalDougherty's profile
HalDougherty
1820 posts in 1406 days
#14 posted 496 days ago
Don,
The MLCS horizontal router table looks like a winner to me. Only the price is a little high if you buy it and all the options they offer… So, I’m going to use the photos to build my own. It’s not all that complicated, especially since I have several sets of linear bearings and hardened shafts to use. There is a trick to making the shafts parallel. The shafts have to be aligned +/-, 0.002”, or the slide will bind. I’m going to use laminated MDF for the supports and drill 1/16” oversize holes and stabilize one end by wrapping the rods with electric tape till they are a friction fit, then bed the other end with the epoxy bedding compound I use to glass bed rifle actions in my stocks. After the first end sets, I’ll bed the other end. I’ll use the router plate mounted on the rods by the bearings to make line up both rods. This method is close enough for building a jig with wood parts. Here's the link to the MLCS horizontal router table with great views of the table and videos of it in action.
After looking at the videos on the MLCS webpage, I’m just going to take the router plate from my router table and make side supports like the MLCS table. Much simpler and a quick change to go from my regular table and the horizontal table.
-- Hal, Tennessee http://www.first285.com
horky
#15 posted 496 days ago
Don, my mistake and apologies … I thought it was there. I have a sketchup file and will email to you (or anyone else who wants it) as I cannot find a way to attach it to the post. PM me your email address.
Another option for the legs .. make templates from hardboard .. clamp/double stick tape to the legs .. route uisng a guide bushing and spiral up cut bit … here is one I used on some back legs … glued paper to hardboard, drilled/cut out the busing slots … clamp to the leg .. slam bang the legs are mortised …
