Question about when to use table saw zero-clearance inserts
Forum topic by Furnitude posted 01-09-2012 08:29 PM 5106 views 0 times favorited 24 replies Add to Favorites Watch
View Furnitude's profile
Furnitude
380 posts in 3382 days
01-09-2012 08:29 PM
I currently don’t have a zero-clearance insert on my table saw but am getting one soon. My question is when to use an insert. Is it a good rule of thumb to use a zero-clearance insert all the time except when you are making angled-blade cuts?
Thanks, as always.
-- Mitch, http://furnitude.blogspot.com Also blog at http://www.craftsy.com/blog/author/mitch-roberson/
24 replies so far
View Ripthorn's profile
Ripthorn
1454 posts in 2859 days
#1 posted 01-09-2012 08:33 PM
I use mine all the time, however there is probably one case (besides angled or dado cuts) when I shouldn’t: if resawing lumber on the table saw. I occasionally do this and find that it is more difficult for the saw to get rid of the dust if using a ZCI.
View Bertha's profile
Bertha
13495 posts in 2568 days
#2 posted 01-09-2012 08:37 PM
I use mine for all straight cuts. I kept the factory one for angled cuts but it makes me really nervous for some reason. I think you just get used to NOT seeing the gap. I installed a splitter on mine but admittedly don’t use it very often.
View Dwain's profile
Dwain
501 posts in 3734 days
#3 posted 01-09-2012 08:39 PM
All the time. You can even make one for commonly used dado widths, or angled cuts, 45 degrees for example. It’s a good idea to make several and to use as much as possible.
-- When you earnestly believe you can compensate for a lack of skill by doubling your efforts, there is no end to what you CAN'T do
View bunkie's profile
bunkie
412 posts in 3021 days
#4 posted 01-09-2012 08:42 PM
I can’t remember the last time I didn’t use mine. I agree with Bertha, switching back to the factory insert looks scary…
-- Altruism is, ultimately, self-serving
View bondogaposis's profile
bondogaposis
4529 posts in 2226 days
#5 posted 01-09-2012 08:46 PM
All the time. The zero clearance slot will wear over time and get larger. Then it is time to make a new one, but don’t throw the old one away instead use it for angled cuts or dados. I have one for thin kerf blades and another for standard blades. I think I have about 5 of them laying around for different set ups.
-- Bondo Gaposis
View Bill White's profile
Bill White
4823 posts in 3835 days
#6 posted 01-09-2012 08:52 PM
Todos los tiempos. All the time. It does make more dust above the table on some cuts, but the trade off is worth the clean up.
Bill
-- bill@magraphics.us
View TheDane's profile
TheDane
5349 posts in 3537 days
#7 posted 01-09-2012 10:43 PM
I made a batch of zero clearance inserts … one for both by thin and regular kerf blades, as well as a bunch for various widths of dado stacks. About the only time I am not using a ZCI is when I have tilted the blade for some sort of bevel cut.
—Gerry
View Jim Finn's profile
Jim Finn
2599 posts in 2796 days
#8 posted 01-09-2012 10:56 PM
I use it all the time my blade is set to 90 degrees.
View Sawkerf's profile
Sawkerf
1730 posts in 2943 days
#9 posted 01-10-2012 12:57 AM
I only use mine when I’m worried about tear out, or ripping really thin pieces which may want to drop into the throat opening.
A ZCI can really restrict the airflow around the blade, and I see better dust collection when I’m using the factory insert.
TheDane
#10 posted 01-10-2012 01:10 AM
Sawkerf—That used to be a problem for me, but last fall I installed a Shark Guard.
With a Shopvac hose connected both above and below the blade, dust/chip collection on the table saw is the best I have ever had.
—Gerry
View doninvegas's profile
doninvegas
334 posts in 2782 days
#11 posted 01-10-2012 01:43 AM
I’m another one that uses it all the time. But remember to remove it when you ar angling the blade or you’ll brake it. Don’t ask me how I know that.
-- "Courage is being scared to death -- but saddling up anyway."
View Jonathan's profile
Jonathan
2608 posts in 2925 days
#12 posted 01-10-2012 04:18 AM
I use mine any time that I’m not using a dado set. You can also make one for angled cuts, as mentioned above to eliminate excessive gaps common on factory inserts.
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
Sawkerf
#13 posted 01-10-2012 05:13 AM
Gerry -
Yeah, those are nice, but I’m a real Neanderthal and don’t even know where my blade guard is stashed away. – lol
Furnitude
#14 posted 01-10-2012 07:18 PM
Thanks, everyone. You confirmed what I thought was the case. After nervously watching narrow cut-offs fall down beside the blade, I’m ready to get a zero-clearance insert. Thanks again.
Bertha
#15 posted 01-10-2012 07:31 PM
I wish they made a SharkGuard for my saw. :(
