| Forum topic by Woodshopfreak | posted 559 days ago | 729 views | 0 times favorited | 9 replies | ![]() |
559 days ago |
I was wondering if any one has had or knows about this problem I am in. I want to get the Delta 50-760 soon and so I need to know if it will work on a 15 amp circuit. I know that in the specs it shows that the dust collector only pulls 15 amps but I am worried that on start up it will pull more, or under load it will pull more than that. I also read in Wood Magazine that it pulls 16 amps max. This would put me over the limit and I can’t change the breaker because then that would require alot of wireing changes to be made. If anybody has this delta running on a 15 amp circuit please help. I also have a 1 amp light on the same circuit. My dad said that the circuit breakers are actually rated a little higher than 15 amps but I don’t know how much more. I think this would trip the breaker, but you tell me. I want to change it possibly to a 20 amp circuit but my dad doesn’t want to have to change the wireing. Any help would be greatly appriciated. -- Tyler, Illinois |
