Breaking Down Sheet Goods with Hand Saws
Forum topic by thebenchroom posted 01-09-2012 06:23 PM 8198 views 0 times favorited 18 replies Add to Favorites Watch
View thebenchroom's profile
thebenchroom
47 posts in 2719 days
01-09-2012 06:23 PM
Topic tags/keywords: question
Wondering what you all think the best saw to use to break down 3/4 ply, other than a table saw. Ryoba Saw, or another hand saw? I hate tablesaws personally, but if power is the “only way” would a high quality circular saw be the best choice?
Thanks
-- Twitter-@thebenchroom
18 replies so far
View jmos's profile
jmos
902 posts in 2571 days
#1 posted 01-09-2012 06:48 PM
I use a circular saw and an edge guide. I can’t get a full sheet into my basement shop, so I have to cut every sheet down in my driveway. I lay out 2×4’s underneath to support both sides of the cut. I just break down to rough dimensions so I can handle the pieces more safely on my table saw.
A track saw (Festool, Dewalt or Makita) is also a good option, but costs more. Or you could get a panel saw, if you have the room and the money.
-- John
View Viking's profile
Viking
880 posts in 3397 days
#2 posted 01-09-2012 06:49 PM
Here is how I do it;
http://lumberjocks.com/projects/29870
You also will want to buy / build a straight cutting guide to keep your circular saw going straight down your cut line.
I have also seen others place a 4’ x 8’ sheet of the thick (about 2-3”) insulating foam sheets on the floor and cut plywood sheet with circular saw on top of the foam sheet.
Good Luck!
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
View rodman40's profile
rodman40
166 posts in 2529 days
#3 posted 01-12-2012 02:02 PM
Thanks, I’m going to build one of these for myself.
-- Rodman
View helluvawreck's profile
helluvawreck
32087 posts in 3068 days
#4 posted 01-12-2012 02:22 PM
I have a small shop so I break up plywood quite a lot outside on saw horses. I then bring the parts inside and cut them again on the TS to make them accurate, However, if you use a good strait edge to guide your circular saw carefully you can cut quite accurately and not use the TS. You can even refine this some what more by leaving a small amount for the router to trim again using the strait edge as a guide along with a ball bearing bit or just an edge guide for the router and a strait bit. your strait edges could be just a good strait piece of would with c clamps to clamp them onto the plywood.
helluvawreck
http://woodworkingexpo.wordpress.com/
View hObOmOnk's profile
hObOmOnk
1381 posts in 4329 days
#5 posted 01-12-2012 02:36 PM
I use Japanese saws.
Here’s a video of a device that I use when cutting sheet goods with a kataba.
I bought mine many years ago from Lee Valley, but they no longer carry this model.
They are still made by the Topman Company of Japan.
Japanese Saw Guide
Blessings.
-- 温故知新
View canadianchips's profile
canadianchips
2613 posts in 3199 days
#6 posted 01-12-2012 03:02 PM
Viking has the right idea. You can make straight cuts IF the plywood is supported while cutting it, nothing worse than trying to balance a sheet while making the last 6 inch cut (DANGEROUS TOO)
View mtenterprises's profile
mtenterprises
933 posts in 2895 days
#7 posted 01-12-2012 03:37 PM
I like the above idea.
But years ago I built my own panel saw. Great item for cutting sheet goods in a small shop. Today you can get them for under $1000 on ebay. http://www.ebay.com/itm/Safety-Speed-Cut-PRO1K-Pro-Vertical-Panel-Saw-/170610315567?pt=LH Hope that link is correct I had to hand type it in I couldn’t copy and paste.
MIKE
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
View devann's profile
devann
2246 posts in 2894 days
#8 posted 01-12-2012 10:33 PM
I find that a model 77 Skilsaw works pretty well. Use a straight edge if you have difficulty cutting a straight line.
View brtech's profile
brtech
1052 posts in 3124 days
#9 posted 01-12-2012 11:30 PM
I use the foam board on the floor with a cutting guide and a circ saw. I find it a heck of a lot easier to cut when the whole sheet is supported, even the offcut, rather than working out how to support it up in the air.
I use a regular 1” thick blue foamboard. All you need to do is make sure your blade height is only cutting 1/4” or so into the foam. That’s an easy adjustment. It’s cheap, safe, easy and effective. About the only “trick” I have is to cut off a couple inches on length and width of the board so the clamps from my straight edge can be placed.
View Sylvain's profile
Sylvain
752 posts in 2701 days
#10 posted 01-12-2012 11:57 PM
View Woodknack's profile
Woodknack
12431 posts in 2582 days
#11 posted 01-13-2012 05:39 AM
I use a Porter Cable circular saw and just lay sheetstock flat on 2×4s. Somewhere I have long straightedge although sometimes I just freehand cut (with a line) and true it up on the tablesaw.
My hat’s off to you sir. I wouldn’t even begin breaking down sheets with a handsaw.
thebenchroom
#12 posted 01-15-2012 03:18 AM
Thanks for the advice and tips from everyone….@Hobomonk, man I’m sold on that tip! Thank You
Sylvain
#13 posted 01-15-2012 02:00 PM
I should have looked at the video pointed to by Hobomonk before making any comment.
For those of us living in Europe, this Japanese saw guide is available in Germany :
http://www.fine-tools.com/miter-sawguide.html
They ship to USA but it is expensive unles you buy multiple item to diminish the cost by item.
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
View paratrooper34's profile
paratrooper34
915 posts in 3154 days
#14 posted 01-15-2012 02:24 PM
A circular saw is a good way to break down sheet goods. It is messy and god-awful noisy, but it does work. For the handtool user, it is a much less expensive way to deal with a large volume of sheet goods without going out and buying a tablesaw. For smaller jobs with sheet goods, use your handsaws. I just finished a shelving project under my basement stairway that I used OSB on. I had the 4’x8’ sheets cut in half for ease of movement and transportation and cut everything else in the shop with my panel saw. Worked out great. No noise, no mess, and never a safety concern.
-- Mike
View BobAtl's profile
BobAtl
49 posts in 2895 days
#15 posted 01-15-2012 02:38 PM
One warning about having sheet goods cut at the big boxes where you buy them: Last time I did that, their panel saw was off enough to be a significant problem. So you might want to ask them when they checked/adjusted the saw for squareness before letting them cut. Also, check the lower track where they rest the panel to make sure there’s no trash to affect the position of the panel in it, which would also affect accuracy. And make sure you check them before working with them at home.
-- Bob, Atlanta
