Sandpaper rolls for Delta 18-36
Forum topic by jlt posted 01-09-2012 03:47 AM 2201 views 0 times favorited 3 replies Add to Favorites Watch
View jlt's profile
jlt
30 posts in 2319 days
01-09-2012 03:47 AM
I bought a Delta 18-36 drum sander used. I am looking for where to buy the sandpaper rolls. I would prefer to buy the pre-cut taper but if I have to I could cut my own. I’m not having much luck finding the consumables. The link to Delta replacement rolls from Amazon says they are out of stock and don’t know if/when they will be available. Can anyone tell me where else to look? If anyone is cutting their own, how are you doing it? Thanks.
3 replies so far
View gfadvm's profile
gfadvm
14940 posts in 2656 days
#1 posted 01-09-2012 04:35 AM
Steve’s Wholesale in Tulsa sells replacement strips BUT they are 2” wide and a PITA. I but the 3” bulk rolls from Supergrit and cut my own. Cut them with a pair of scissors. Thetaper on the end will require a little fiddling to get the first one right. Then use it as the pattern for subsequent ones. Its really very simple. I cut several strips of each grit in advance of need which saves a lot of time. There will be a small difference in length between grits as the coarser grit paper is thicker but I have yet to cut a strip too short. Hope this helps. Note that the taper will be different on 2” than 3”.
View jlt's profile
jlt
#2 posted 01-09-2012 05:04 AM
What weight backing is best. It looks like the coarser grits are X weight and anything about about 80 grit is J weight. Will J weight work ok?
gfadvm
#3 posted 01-09-2012 05:38 AM
All of my grits are x weight , I think. Ask the Supergrit person who answers the phone what is best for you. They are very helpful. I was going to order alum zirconium thinking that more expensive meant better quality. They explained why I didn’t want that even though it cost them $ to do so. I appreciated that.
