Need Help see Pictures.
Forum topic by ohtimberwolf posted 01-09-2012 02:19 AM 3341 views 0 times favorited 17 replies Add to Favorites Watch
View ohtimberwolf's profile
ohtimberwolf
858 posts in 2472 days
01-09-2012 02:19 AM
Topic tags/keywords: diy person advice help relocate delta fence
As you can see I need a lot of advice. I just got my new Delta Fence installed and the tables set up the way I want them but I don’t know the best way to place the following items. Most things can be moved but a few I would rather not due to the amount of work involved. Those are the Table Saw as is of course, the radial arm saw, the metal cabinets are all full but one, lumber rack, work benches and the 5 ft x 10 ft project table that the Delta fence box is resting on. Here is a list of what I have to relocate.
Router table
Band Saw
Drill Press
Dust Collectors
Miter Saw
Large Home-made Belt Sander
Metal Band Saw
Grinder
Wire wheel
6 inch Jointer
I do not have a business I’m just a DIY person so I don’t have to worry about employees. My shop is 20’ wide and 40’ long. That is what I have to work with.
ALL opinions are invited as one idea seems to lead to a new one. Larry
-- Just a barn cat, now gone to cat heaven.
17 replies so far
View ocwoodworker's profile
ocwoodworker
209 posts in 3124 days
#1 posted 01-09-2012 02:27 AM
You might want to take your router table and combine it with the right-side TS top. It is a great saver of space.
The DC should drop down from overhead and (if possible) be located outside in a storage shed. (opens up floor space/ cuts down on noise/ and micro-pleated material becomes moot.)
Have fun!!!
-- I'd like to believe Murphy's Law haunts my woodshop, because if it's Karma it would mean I had something to do with it. - K.R.
View papadan's profile
papadan
3584 posts in 3488 days
#2 posted 01-09-2012 02:35 AM
It might be easier if you post a diagram of your shop with all the items that can not be moved in place and the rest of the area left blank. Then we could see what would work best for placement of the rest of your tools. Make sure you include any windows and doors in the diagram.
ohtimberwolf
#3 posted 01-09-2012 02:38 AM
Good Ideas, I’ll work on a diagram and post it when done. larry
117203 posts in 3697 days
#4 posted 01-09-2012 02:43 AM
It’s all trial and error . I must have rearranged my shop a 200 times over the years.
View Grandpa's profile
Grandpa
3261 posts in 2795 days
#5 posted 01-09-2012 04:45 AM
Grizzly has a system where you can select tools and place them in the shop that you dimension. You might start there and then you would have an idea of how you want to place things.
ohtimberwolf
#6 posted 01-09-2012 01:34 PM
Grampa: Good idea,that could help along with the rest of the suggestions. I’ll see if I can find it.
ohtimberwolf
#7 posted 01-12-2012 01:48 AM
Couldn’t find the shop setup on grizzly but I got a lot done in the shop. I’ll take pictures and post them and a diagram of the space left for use on Thursday (tomorrow).
I have all the tools that need placed in a group to make it easier for you guys helping me to offer suggestions. I’ll post the dimension of each one and the open area also. The new pictures will help you get a better view of what needs to be done. larry
View Tyrone D's profile
Tyrone D
314 posts in 2453 days
#8 posted 01-12-2012 02:03 AM
The Grizzly shop setup program is somewhere on the Grizzly site. I’ve used it before.
I can’t really help you with the organizing, I’ve got enough on my hands designing mine.
What brand is your band saw? It looks identical to mine and I’ve yet to find any information on my bandsaw.
EDIT: http://www.grizzly.com/workshopplanner.aspx
I just happened to need to go to Grizzly.com. It was on the front page.
-- --Tyrone - BC, Canada "Nothing is ever perfect, we just run out of time."
Rick Dennington
6089 posts in 3314 days
#9 posted 01-12-2012 03:59 AM
GEEEZ…I wouldn’t even know where to start in your shop…lol. I’d probably move eveything out and start all over… Try to arrange your work flow…..by that I mean center the tablesaw so as to have plenty of room all the way around it (at least 8 ft.) for handling sheet stock and long boards. Place your jointer, planer, RAS, miter saw, etc. to create a work flow, so you can move from one machine to the next smoothly, and not have to walk your legs off getting to one. Tablesaw with outfeed table to diminision lumber, then to the jointer, then planer, then mitersaw, et.c , etc…..then on to the assembly table, if you have one….keep it tight….keep it close…..keep things up and out of the way…..a place for everything and….you know the rest…once you get the workflow area squared away, you’re in business…...here’s what I’m talking about…..see my woodshop pictures, and woodshop pics #2 under my blogs….....
-- " It's a rat race out there, and the rats are winning....!!"
ohtimberwolf
#10 posted 01-12-2012 02:03 PM
Wow Rick, what a nice shop. A real inspiration to get mine looking something like that. I’ll never have that kind of cabinet work. That is Great!
I have a built on work bench across the window end of the shop that will have to stay. On the long (right) side I have about 9 or ten feet of table to the left of my RAS and about 5 ft on the right side. All that is built on. On the left from the window workbench is another 7 ft workbench that holds my router things, metal clamps pipe wrenches and hacksaw, punches & the likes.
I think my biggest problem is I have too many needs rolled into one shop. Welding, all my rental property repair needs, stained glass items, lawn tractor items, minor mechanical stuff, metal lathe, electric hack saws, plumbing and on and on all in one shop.
I may have to close off a portion of the barn for a lot of these other things in order to get it organized but then things are so scattered out when I need them. Just not sure how to handle it. The metal cabinets are all full but one. I also have all sorts of cut off pieces that I hate to get rid of because I’m always pulling something out of that mess to use. Sometimes I feel like selling everything and then just go fishing.
I’ll update my status with pictures and dimensions later today. larry
View helluvawreck's profile
helluvawreck
32073 posts in 2986 days
#11 posted 01-12-2012 07:28 PM
I noticed some things on rollers and some things not on rollers. The more things that are on rollers in a small shop the better off you will be. Everything in my shop is on rollers except for the drill press and main work table. Anything except those two that is not connected to the walls is on rollers. While I’m working on projects I move some things from here to there and it’s not a problem. Considering my room I am very happy with the way that I have everything arranged and everything usually stays where it is. But if I need to move something temporarily I can do it. If it were otherwise I would run into all kinds of problems.
helluvawreck
http://woodworkingexpo.wordpress.com/
Rick Dennington
#12 posted 01-12-2012 07:57 PM
helluvawreck,
Very good point, sir…I forgot to mention in my post that I also have all my major machines on casters, except things like the tablesaws, workbenches, RAS and miter station, & drill press…. all the rest are mobil and can be moved to anywhere in the shop…..even the two assembly tables are on casters…..Once I’m finished with them, they are moved back to “where they live” till the next project…..everything has its place….Glad you brought up that point, cause I sure forgot to. It was pretty late when I posted, so I was probably getting sleepy by then….:)
ohtimberwolf
#13 posted 01-13-2012 12:09 AM
What I need is advice on placing the tools left over in the space shown in red. The one cabinet with the red line to it will be gone soon. The items listed with their sizes are what I need help on locating. Maybe I should just bunch them up and use them as I need them. larry
View StumpyNubs's profile
StumpyNubs
7649 posts in 2920 days
#14 posted 01-13-2012 12:21 AM
Not to plug my show or anything (actually, that’s exactly what I am doing), but I have a small shop and I think you may like some of the layout we have! (Episode 5 has a lot of shop layout info)
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications: http://www.stumpynubs.com/
View jerkylips's profile (online now)
jerkylips
447 posts in 2690 days
#15 posted 01-13-2012 12:32 AM
Stumpy – didn’t you get kicked off a website for that? haha!
