What wood do you use for jigs, etc?
Forum topic by greatview posted 498 days ago 1217 views 0 times favorited 22 replies Add to Favorites Watch
View greatview's profile
greatview
60 posts in 1325 days
498 days ago
I’ve essentially switched to almost exclusively MDO which my local lumber stocks in 1/2” (good both sides) and 3/4” (good both sides and good one side) With the paper facing it is easy to do a layout directly on the surface and, if I need to paint, it accepts paint very well. I’ve also used it where I might have used birch veneer that I might have painted. Same edge problem but it is a really nice surface. And, it is really waterproof and will work for out side applications. (Around here, some of the highway signs are made from it.)
About the only downside I’ve discovered is that glue doesn’t adhere well to the paper facing. But with a bit of sanding to roughen the surface, glus will stick.
-- Tom, New London, NH
22 replies so far
View Gene Howe's profile (online now)
Gene Howe
3190 posts in 1596 days
#1 posted 498 days ago
MDO, MDF, BB. are my favorite jig materials. Of those, I’d say that I prefer BB. Cost/benefit analysis.
View NiteWalker's profile
NiteWalker
1469 posts in 744 days
#2 posted 498 days ago
I use baltic birch for most of jigs and router templates.
I used to use MDF a lot, but try to stay away from that now.
View doncutlip's profile
doncutlip
2808 posts in 1723 days
#3 posted 498 days ago
BB and MDF so far. MDF seems to hold up pretty good, but oh the dust it makes. I get dust in every corner of my shop when I work MDF.
-- Don, Royersford, PA
View richgreer's profile
richgreer
4474 posts in 1242 days
#4 posted 498 days ago
I usually just grab what is handy.
However, I learned a lesson last summer I will share. W needed templates for the pew ends we were making for our church. Because we were producing a large quantity of them, I made 3 identical templates and I used OSB because I had some available. We used a template to draw the shape of the pew end in pencil. Then we cut them out crudely with a band saw and/or jig saw. Then, with a template attached with a couple of screws that would be in a hidden location, we router the edges with a straight bit and guide bearing.
My discovery was that after routing several pew ends (between 10 and 15), the OSB started to break down causing an uneven edge on the pew end.
View Ben's profile
Ben
248 posts in 498 days
#5 posted 498 days ago
I agree with Rich. I use whatever is handy and make a lot of jigs on the fly as I need them. I will use anything I can do get what I need done. Jigs don’t need to be pretty at all, just functional. A lot of my jigs are one time use, so I don’t spend a ton of time or waste good wood on them. Some that I know I will get a lot of use out of, I build to last. I have a general aversion to OSB and MDF, so I rarely even have any in the shop
-- Welcome to downtown Coolsville, Population: US! --Hogarth Hughes
View gfadvm's profile
gfadvm
6623 posts in 857 days
#6 posted 497 days ago
MDO? I have always used BB ply but recently my sled has developed a bow in it which is very disappointing. It has never been wet and is stored on edge so this shouldn’t have happened.
View handi's profile
handi
114 posts in 2607 days
#7 posted 484 days ago
If you have not tried it, you need to look at phenolic faced plywood. Comes in 1/2” and 3/4” (I typically make jigs in 1/2”)
Basically, it is better quality baltic birch (no voids) that is used for concrete forms. The two faces are coated in a thin layer of phenolic. Both Rockler and Woodcraft sell it. It is pricey, but stays very stable and machines well.
Phenolic Faced Ply
I especially like it for jigs that I intend to use for a long time. You can see some of it used in my insert throat plate.
Ralph
-- www.consultingwoodworker.com
View bugz's profile
bugz
380 posts in 831 days
#8 posted 484 days ago
Next trip thur denver I hope to get a sheet or two of the phenolic ply but in the mean time I use only BB. mdf dust is not good. I think you can get 4 X 8 sheet of the phenolic ply at whitecap supply. With the plastic face it is very stable.
-- Bob, Lewistown, Montana. Kindness is the Language the blind can see and deaf can hear. - Mark Twain
gfadvm
#9 posted 484 days ago
No one has told me what MDO stands for. PLEASE???
View TCCcabinetmaker's profile
TCCcabinetmaker
735 posts in 522 days
#10 posted 484 days ago
pretty much whatever 3/4 plywood I have laying around. I just make them to do what must be done, not to look pretty.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
View Bagtown's profile
Bagtown
1636 posts in 1897 days
#11 posted 484 days ago
gfadvm – I had to look it up too.
Have a look here.
Mike
-- http://www.heartofsackville.ca/
gfadvm
#12 posted 483 days ago
Thanks Mike. I have never seen this and not sure where to get it in my area. It sounds like it would be good for jig material. Phenolic ply seems very pricey here. Maybe this is less expensive. Andy
View stefang's profile
stefang
9448 posts in 1501 days
#13 posted 483 days ago
Where strength is required I like Baltic Birch plywood, otherwise Mdf for it’s flatness. The phenolic ply is excellent stuff and when I can pick up some offcuts at a cheap price I buy it for jigs.
-- Mike, American in Norway
View JAAune's profile
JAAune
253 posts in 484 days
#14 posted 483 days ago
My preference is cabinet grade particle board since it’s the cheapest and is stiffer than MDF. If that’s not available then it’s usually scraps of whatever is on hand. If a smooth, durable edge is needed then my choice is usually MDF with epoxy-coated edges.
Jigs intended for long-term use are made with more care going into material selection.
TCCcabinetmaker
#15 posted 483 days ago
particle board is not cabinet grade…
