Shellac or Lacquer Over BLO ?
Forum topic by gfadvm posted 502 days ago 971 views 0 times favorited 8 replies Add to Favorites Watch
View gfadvm's profile (online now)
gfadvm
6650 posts in 861 days
502 days ago
Topic tags/keywords: shellac and lacquer for small projects
I have not used shellac or lacquer ever and have some questions. Can I apply it over BLO? How long should I wait (patience is not one of my virtues)? Any tips, cautions, or other shellac/lacquer advice appreciated. I’m talking about small projects (boxes) so I hate to use/clean up my sprayer for something this small. Thanks for all the good advice I know I’m going to recieve!
8 replies so far
View Bill White's profile
Bill White
2608 posts in 2132 days
#1 posted 502 days ago
I use a lot of shellac as a sealer and as a final finish. It’ll go on anything, and is an easy cleanup. Brush, spray, wipe will work. Clean up with water and amonia (generic is fine.) Not too resistant to water/alcohol damage, but can be easily recoated if needed. I mostly use the Zinsser Seal Coat. It is dewaxed.
Bill
-- bill@magraphics.us
View grizzman's profile
grizzman
5397 posts in 1475 days
#2 posted 502 days ago
andy you can buy lacquer in a spray can, so no clean up is needed, this should be used with sanding sealer, in my opinion, as the sanding seal does just that, it seals your wood, , it fills the pores of the wood and if done with several coats, then your lacquer goes on with a mirror finish, it dries very quickly and can be applied with thin coats, i like it for certain types of projects, but as finishes go, there are many and i think you should maybe get some books from some of the better box makers and get there thoughts. i do think there are better finishes when it comes to boxes, and im still learning myself…so keep on learning , i think by reading what the expert box makers use , we cant go wrong..but with as many finishes as there are, you might find you like one over the other,have fun, its a real enjoyable quest…grizz
-- GRIZZMAN ...[''''']
View Chipy's profile
Chipy
378 posts in 765 days
#3 posted 502 days ago
I have used MIMWAX spray poly and have had good success.It comes in a spray can with a decent spray pattern.I bought mine at HD I think for about $8 a can. I am learning to be a fan of finishing and like you I am sometimes short in the patience department but I don’t think I would haul out a big rig for something as small as a box.I have HVLP Earlex system on the way but I will probably still use spray cans for the small stuff.Hope I was some Help Chipy
View planeBill's profile
planeBill
300 posts in 580 days
#4 posted 502 days ago
As far as wait time. Depending on the conditions in your shop, at least 24 hours but I have found 48 to be my minimum.
-- I was born at a very young age, as I grew up, I got older.
View Clint Searl's profile
Clint Searl
850 posts in 533 days
#5 posted 502 days ago
Solvent lacquer is my go-to finish. It doesn’t need any “sealer” as it’ll stick to any wood and can be built up to fill grain as easily as anything else except paste fillers intended for that purpose. It’s available in any degree of sheen and can be rubbed out if necessary. Also, finishing can be completed in a day. For small projects, I use a detail or touchup gun. Cleanup is just as easy as washing out a brush. In my experience, it has been the most successful film finish.
-- Clint Searl.............We deserve what we tolerate
View michelletwo's profile
michelletwo
1767 posts in 1187 days
#6 posted 502 days ago
If you are in a hurry, shellac is your product. I use it on turnings about 75% of the time. Dries FAST
-- We call the destruction of replaceable human made items vandalism, while the destruction of irreplaceable natural resources is called development.
View Alan Robertson's profile
Alan Robertson
67 posts in 2090 days
#7 posted 502 days ago
I like shellac for large and small projects. Try a 50/50 – shellac/denate alch. mix. If your work area is reasonably warm, will dry within 30 min. For boxes—- apply several coats, allow to dry, steel wool, paste wax-buff, give box to someone who will appreciate it. Shellac is an reasonably durable interior, safe finish. Was used as a pill coating. FDA approved for childrens furniture. Try it, fool around with the mixture. An almost fool proof finish.
-- MrAl
View 3Gwoodguy's profile
3Gwoodguy
152 posts in 864 days
#8 posted 502 days ago
these are alll great inputs…I would just add. The smell of shellac is much lighter and appealing to me. One amazing experience I had was after laying down a coat of stain, I noticed how strong the stain still smelled even after drying. I applied the shellac, and it sealed up the stain and after the shellac was dry virtually no smell of the stain. Really no smell at all. .......and its all natural.
-- "The beatings will continue until moral improves" -- Bart Ridings, Illinois
