Homemade Shopsmith surface sander.
Forum topic by Hanman posted 01-08-2012 01:04 AM 9688 views 0 times favorited 5 replies Add to Favorites Watch
View Hanman's profile
Hanman
58 posts in 2386 days
01-08-2012 01:04 AM
Topic tags/keywords: sander shopsmith homemade plans
Hello all! I’ve been looking for good plans to make my own surface sander attachment for my shopsmith. Actually this is how I found this website. I’ve seen several pics and descriptions about how to build the drum and how to mount it, but still haven’t figured out a good way to feed stock through it. Any tips or links to good plans would be greatly appreciated.
-- It is amazing what you can accomplish if you do not care who gets the credit. - Harry S. Truman
5 replies so far
View Tootles's profile
Tootles
808 posts in 2556 days
#1 posted 01-08-2012 04:07 AM
Have you been looking at this one? It’s probably as good as you will get. Plus Paul did a blog on the process of making it. He’d probably also answer questions if you sent him a pm directly.
-- I may have lost my marbles, but I still have my love of woodworking
Hanman
#2 posted 01-08-2012 05:36 PM
checked it out. exactly what I was looking for. Thanks.
View SASmith               's profile
SASmith
1850 posts in 3041 days
#3 posted 01-08-2012 07:10 PM
If I were to make one for the shopsmith I think I would make it a v-drum style sander where you pass the wood over the top of the drum like a jointer instead of under it like a planer.
Like this
Here is another concept shipwright drew up:
And a hand crank conveyor model:
-- Scott Smith, Southern Illinois
Hanman
#4 posted 01-08-2012 10:15 PM
@SASmith- this looks good too. How does it work for you? What is the black crank I’m seeing there? Is that how you feed the stock through? I guess I don’t know a lot about these sanders, I always thought the stock was fed through mechanically similar to a planer. If that’s not the case, how do you feed it through? Thanks again guys, appreciate the info.
SASmith
#5 posted 01-09-2012 01:22 AM
The above pic is not mine it came from the thread in this link.
The pic above uses the hand crank to move the belt/conveyor forward.
The link that tootles made above is a manual model that you just push though at a steady speed, no conveyor.
That is why I recommended a “v-drum” style sander that you use like a jointer. Below is an example:
You can search here on lumberjocks for “v-drum” or “v drum” to see more examples of what I am talking about. Most are not powered by a shopsmith, but you can get an idea of how they work.
