YIKES!! It Costs How Much
Forum topic by ohtimberwolf posted 01-07-2012 07:59 PM 2429 views 0 times favorited 40 replies Add to Favorites Watch
View ohtimberwolf's profile
ohtimberwolf
799 posts in 2352 days
01-07-2012 07:59 PM
Topic tags/keywords: belt power twist table saw
I wanted to put a new belt on my Delta 10” contractors saw in my shop and priced the Power Twist Belts and nearly fell off my chair.
Are these belts really worth 8-10 dollars a foot? Is there a good alternative that I could buy? I’m just a DIY person
-- Just a barn cat, now gone to cat heaven.
40 replies so far
View Viking's profile
Viking
880 posts in 3195 days
#1 posted 01-07-2012 08:09 PM
The one’s at Harbor Freight are just as good and a lot cheaper. $25 for 5 ft. belt and about $20 if you have one of their 20% off coupons.
http://www.harborfreight.com/vibration-free-link-belt-43771.html
Good Luck!
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
ohtimberwolf
#2 posted 01-07-2012 08:14 PM
Viking, thanks for the tip and the fast help. I will check it out. Larry
View syenefarmer's profile
syenefarmer
488 posts in 3081 days
#3 posted 01-07-2012 09:02 PM
Short sweet answer, yes they’re worth it. Also, nothing wrong with the HF version.
View JohnnyM's profile
JohnnyM
39 posts in 2333 days
#4 posted 01-07-2012 09:31 PM
+1 on they are worth it and I have used HF belts and like them.
-- ~~ John . . . . . . . . . Against the Grain Woodworking & Design, LLC
View JollyGreen67's profile
JollyGreen67
1669 posts in 2763 days
#5 posted 01-08-2012 12:29 AM
The only difference in the belts you find at HF is the color – green. By the way – mine was made in the USA.
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected !
View taoist's profile
taoist
124 posts in 2491 days
#6 posted 01-08-2012 12:44 AM
I hope it works well for you. Please post your results when you get the new belt installed. The reason I ask you to post results is that I also have a Delta Contractors saw. It really is pretty steady except during start up. I was thinking about replacing the belt with one of the link belts but unsure if the pulleys didn’t need to be replaced too.
View Bill White's profile (online now)
Bill White
4932 posts in 3961 days
#7 posted 01-08-2012 12:56 AM
I put one on my 1955 Magna Band saw. Wow!
I must have been drinkin’ when I paid the price 15 years ago, but it was worth it.
Bill
-- bill@magraphics.us
ohtimberwolf
#8 posted 01-08-2012 02:14 AM
Well I ordered it at HF as suggested. Looked around and got a 20% code off the net. Total cost of $28.67 for 5 ft. For those interested the code is 2OSAVE http://dealspl.us/harborfreight-coupons
The code is good for 1 item and only good one time. It worked for me, some said it didn’t work for them????
I’ll report back when I get it and tell you what I think. Thanks to all. It is coming slow ups so it will be a little while till I get it. Larry
View agallant's profile
agallant
551 posts in 2887 days
#9 posted 01-08-2012 05:12 AM
Can you use an old AC belt from a car?
View tenontim's profile
tenontim
2131 posts in 3745 days
#10 posted 01-08-2012 01:58 PM
The link belts work fine, until you bind the blade and make a burn spot on the belt. Then it’ll vibrate like the dickens. Be sure to have some extra links for repairs.
Viking
#11 posted 01-08-2012 02:53 PM
I did try a Gates Power Belt (AX Series) on an older Craftsman contractors table saw. It was a big improvement over the original v-belt which had taken a set from low use. The Power Belts have the grooves on inside that prevent the set. That belt was about $7 as I recall. I ran the PBS for a few weeks then put a link belt on the saw and saw very little change in vibration.
View canadianchips's profile
canadianchips
2600 posts in 2997 days
#12 posted 01-08-2012 03:05 PM
A good quality belt IS WORTH the money, elimates chatter and lasts longer during hard use.
Viking
#13 posted 01-08-2012 03:17 PM
You can typically see even more reduction in vibration by replacing the OEM pulleys, which are cast, with a couple of machined pulleys.
Also spend a little time aligning the pulleys with a straight edge.
View northwoodsman's profile
northwoodsman
242 posts in 3747 days
#14 posted 01-08-2012 05:31 PM
The link belt is the only item that I have ever purchased at HF. They work fine. I have a couple that I also purchased at Rockler on sale and the only difference is the color. By the way, the links are not easily interchangable between the two brands. I had just enough left over from the Rockler one and just enough from the HF one to make another belt. It took some modification but I got it too work. The links are a different length as is the slot. You have to make one slot longer and cut one tab shorter for a really good fit to combine the two.
-- NorthWoodsMan
ohtimberwolf
#15 posted 01-09-2012 02:04 AM
Thanks for the good advice guys! I never thought about pulley alliginment or changing the pulleys for machined ones.
I just got my new Delta Fence put on my saw and the tables installed abound it and am going to start a new post with pictures because I need a lot suggestions on setting up the rest of my shop tools for use. I don’t want to have to move them again when I’m done. Larry
showing 1 through 15 of 40 replies
