| Forum topic by USCJeff | posted 561 days ago | 285 views | 2 times favorited | 7 replies | ![]() |
561 days ago |
I posted this as a project yesterday, but thought I’d follow up in the safety section as that is really the more pertinent location. Anyways, you can link to the project for all the construction details as well as a link to the very thorough resource from another woodworker used to base mine on. I took some liberties, but the concept is about the same. While it’s not an Excalibur or Penn State version, I constructed it for about $30 since I had the long 2.5” Steel square tube on hand. The original author claims he spent $100. He used some larger/thicker parts than I did, however. Needless to say (but I will), Western Saw blade guard standards are terrible in comparison to those overseas. They are a pain to take on and off and restrict the wood more so than provide safety in many cases. If you are like me, your’s didn’t see much action. Recognizing the risks, I finally took the plunge and made the best compromise I’ve seen so far. Safety and functionality. Does it get in the way. . . somewhat. But, nothing in comparison. I timed myself removing it and it took about 30 seconds to loosen the two wing nuts. About the same to put it back on. Here are some photos (See project for larger images): One thing I found right away is that a variety of push blocks and featherboards are paramount. They can reach under and around guards leaving hands free to move the workpiece without interference. I haven’t made it a habit yet, so it still feels like it is taking longer. Hopefully that will change with time. I now keep them on hooks and magnets on the vertical support so that there is no excuse to grab one. Dust Collection hookups are easy to add on. Cut a hole the size of the desired splice and drape the hose down the support. My DC cfm rating is preventing me from doing this until I get a better collector. I can’t split the air flow and have decent suction in two places just yet. My middle of the row Shop Vac’s do a little, but really not enough to make a permanent hook up. -- Jeff, South Carolina |
