The Why Thread
« back to Hand Tools forum
Forum topic by papadan posted 01-07-2012 04:33 AM 2246 views 0 times favorited 57 replies Add to Favorites Watch
View papadan's profile
papadan
3584 posts in 3366 days
01-07-2012 04:33 AM
Topic tags/keywords: question resource
Anything you wonder why, post here and we’ll see if someone can answer. I would like to know WHY carving mallets are round and tapered?
57 replies so far
View GMman's profile
GMman
3902 posts in 3695 days
#1 posted 01-07-2012 04:37 AM
Very good question papa
GMman
#2 posted 01-07-2012 04:42 AM
kolwdwrkrsgirl is a carver.
View David Kirtley's profile
David Kirtley
1286 posts in 2996 days
#3 posted 01-07-2012 05:54 AM
Easy answers.
The taper is ergonomic. If it were parallel, you would have to hyper-extend your wrist to hit something.
Round is so you don’t have to keep turning it in your hand as you are carving to keep the face oriented to the tool. Carving changes direction often.
View lew's profile
lew
12056 posts in 3753 days
#4 posted 01-07-2012 07:00 AM
David’d answers sound reasonable.
Rick Dennington
5859 posts in 3192 days
#5 posted 01-07-2012 07:10 AM
I’d like to know why A1Jim has 30 routers…..? Does he just grab another one if the bit goes dull on the one he’s using?
papadan
#6 posted 01-07-2012 07:15 AM
Those answers make complete since to me. I’m just getting started in carving and haven’t turned my mallet yet. Rick, Jim keeps a different bit in each one so he doesn’t have to waste time changing them during his jobs. Next WHY?
Rick Dennington
#7 posted 01-07-2012 07:31 AM
Why can you only buy dowel rods in 3 foot lengths ?
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2353 days
#8 posted 01-07-2012 07:49 AM
why jobs never go as planned…
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
View pintodeluxe's profile
pintodeluxe
5658 posts in 2811 days
#9 posted 01-07-2012 07:55 AM
Why don’t hollow chisel mortisers index the chisel square to the fence? Honestly if my sonicare toothbrush can index square, why can’t my Delta mortiser?
View SalvageCraft's profile
SalvageCraft
274 posts in 2524 days
#10 posted 01-07-2012 08:17 AM
Why do I always chip a blade right after I change or sharpen it?
Why does a 12 foot long 2×8 measure 145”x1.5”x7.25”?
Why do I build or buy more stuff for the shop than for everything else combined?
-- Jesse --
David Kirtley
#11 posted 01-07-2012 08:18 AM
30 routers is not excessive if you are making a living at woodworking. Nobody is paying you for changing bits and readjusting depths. You have to be spending your time cutting wood. Adding another router is cheap and can save many times its purchase price in short order. Have a dovetail jig all dialed in? One dedicated router for the pins, another for the tails that just live with the jig and they are not messed with other than changing to a sharper bit when needed. Maybe another one for a box joint jig. Another two for making drawers with dadoes for the back and groove for bottom. Several different rabbeting, radius and chamfer bits. Another set up for mortising hinges. or other cabinet hardware. One with a pattern bit for copying pieces or following templates. Others dedicated to other jigs and tables for different operations. They add up really quickly.
I have 6 and I am mainly a hand tool person. Technically 10 if you count the small rotary tools.
One big Triton dedicated to big router table with Incra Fence. It handles knots much better than my plow.
One little one dedicated to a small router table—second operation without changing setup. Usually grooving.
2 laminate trimmers- one dedicated to the threading jig, one to use for actually trimming stuff.
1 rotozip soon to be the spindle for a CNC router.
One plunge router with template guide (But that may change to a horizontal router table)
View David Craig's profile
David Craig
2137 posts in 3107 days
#12 posted 01-07-2012 09:22 AM
Another reason why carver’s mallets are round is to allow the carver to eye their piece while making the cuts and not rely on eye/hand coordination between the mallet head and the chisel. Since the mallet is round, the carver can safely hammer on the chisel and not miss the “sweet spot” that a hammer head mallet would require. His/her eyes never have to drift away from the cutting edge.
David
View Don Butler's profile
Don Butler
1092 posts in 3393 days
#13 posted 01-07-2012 01:42 PM
Why do we say, “Left, right, left, right” (example: marching)?
Why couldn’t it be “Right, left, right, left”?
Sure, it’s a standard meant to keep everyone on the same page, so to speak.
But who decided it would be “Left right”, and not “Right, left”?
Inquiring minds want to know.
ddwwb
-- No trees were damaged in posting this message, but thousands of electrons were seriously inconvenienced.
View Chipy's profile
Chipy
374 posts in 2591 days
#14 posted 01-07-2012 02:57 PM
Don….Actually a little known fact that the “left right”concept was invented by Orville Wright.One day Orville said to Wilbur do have any ideas left on this problem of weather it should be “right left” or “left right”? Wilbur said the right way to march would be “left right” right, Wright….because if you started marching with your right instead of your left it would be just wrong right,Wright?
View flintbone's profile
flintbone
201 posts in 3154 days
#15 posted 01-07-2012 03:15 PM
What do you call the little button on top of a ball cap?
I know this isn’t a “why” question but it causes me to lose sleep.
flint
-- If I had only known, I would have been a locksmith. - Albert Einstein
showing 1 through 15 of 57 replies
