| Forum topic by Jon Anderson | posted 528 days ago | 2275 views | 0 times favorited | 42 replies | ![]() |
528 days ago |
Topic tags/keywords: question tablesaw Is there away to do this without having to buy some exotic chemical cleaner , Cost is alway a factor.. -- jbander |
42 replies so far
#1 posted 528 days ago |
I think this has come up once or twice before. ;-) There are many ways to do it…the important thing as that it gets done regardless of which method/cleaner you use. Saw blade cleaning discussions -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#2 posted 528 days ago |
I have only used a pitch remover I bought at woodcraft. I don’t cut it, just use it full strength and than put it through a paint/finish strainer and back into the bottle. Been using the same bottle for a good 8 years now. The stuff works like a charm. -- ~~ John . . . . . . . . . Against the Grain Woodworking & Design, LLC |
#3 posted 528 days ago |
I use the Simple Green Pro (purple stuff) from Home Depot. It works great and not expensive. -- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas |
#4 posted 528 days ago |
Every once in awhile I get a bunch of pine sap on my hands… STICKY as all get-out! I’ve been using plain ole Dawn liquid dish washing soap.. I may have to try 2-3 times… but, it eventually works for my skin. How that correlates to a saw blade, I don’t know… And, when I do it, the sap is still soft... If I were to let it harden, I doubt if the soap would do it. -- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?ppuser=1389&cat=500" |
#5 posted 528 days ago |
the simple green cleaners and the orangecleaners both work for me just fine. I usually take the blades off my table saw and miter saw every couple of weeks and give them a good cleaning. Makes a nice difference. -- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. http://www.FineArtBoxes.com |
#6 posted 528 days ago |
I use Simnple Green. Let blade soak in it for 10 minutes, then scrub balde with an old tooth brush, rinse and dry. |
#7 posted 528 days ago |
Another call for Simple Green -- Don't anthropomorphize your handplanes. They hate it when you do that. -- OldTools Archive |
#8 posted 528 days ago |
It’s Dawn dishwashing liquid for me. Hot water, a good squirt of Dawn and let it sit an hour or so in a baking sheet deep enough to cover the blade. Think I set the blade on a few coins or something to ensure good contact all the way around. Not sure just how long it takes because I left my blade soaking a few hours while I went to church one Sunday. I used a nylon household brush to get all the softened gunk from the gullets and around the teeth but it came off real easily with just one soaking. -- Bob, Atlanta |
#9 posted 527 days ago |
Soak in soap and hot water. Scrub teeth with a bristle |
#10 posted 527 days ago |
Thanks for the great response and thanks for the kind welcome, simple green sounds like it has a lot of support, is it because it is more environmentally sound or does have something extra to recommend it. -- jbander |
#11 posted 527 days ago |
Jon, Dawn & other dish washing liquid soaps are OK with the environment… -- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?ppuser=1389&cat=500" |
#12 posted 527 days ago |
Simple Green works quickly and is ‘non-toxic, biodegradable.’ It’s an effective stain per-treat on many fabrics too. -- Don't anthropomorphize your handplanes. They hate it when you do that. -- OldTools Archive |
#13 posted 527 days ago |
I’ve used washing soda and goof off they both work very well. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#14 posted 527 days ago |
1+ for simple green purple. Cleans blades very easily and will not degrade carbide like regular simple green. $15 at home depot will get you a concentrated gallon that will lasts you years. -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
#15 posted 527 days ago |
Really, how does simple green degrade carbide, do any of the other suggestions also degrade carbide. -- jbander |
| Forum | Topics |
Woodworking Skill Share
8842 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
68 |
Joinery
96 |
Finishing
1597 |
3591 |
15972 |
Hand Tools
2093 |
Jigs & Fixtures
501 |
Wood & Lumber
2906 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2772 |
LumberJocks.com Site Feedback
1551 |
Coffee Lounge
6130 |
