White Splotches in Varnish
Forum topic by Alan S posted 01-06-2012 06:30 AM 904 views 0 times favorited 1 reply Add to Favorites Watch
View Alan S's profile
Alan S
180 posts in 3222 days
01-06-2012 06:30 AM
I applied a coat of Arm R Seal to some mahogany on Sunday of this week. The pieces have set in my unheated garage and the temperature outside has been between 65 and 35 F. I believe on Wednesday, I noticed a white splotch in an area of the finish. I sanded down the whole piece with 220 grit sandpaper that day (white powder is what came off while sanding) and applied a 2nd coat. Today, I noticed more white splotches, probably where I applied the varnish a little bit thicker. What’s going on? I thought 3 days to dry would be enough even in this colder weather. Do I need to heat my garage? Help, Please!
BTW, on Saturday, I stained the mahogany with GF water-based dye stain. Was a day not long enough for the dye to dry?
Edit 2: Maybe what I am seeing is called blushing? At 11pm tonight, weather underground says the humidity here is 75%. I also read I might be able to get rid of it with a hair dryer by evaporating the trapped moisture causing the blushing. Thoughts?
Alan
1 reply so far
View Edziu's profile
Edziu
151 posts in 2955 days
#1 posted 01-06-2012 08:22 AM
Hey there Alan. I believe you are experiencing are friction spots. Arm-R-Seal is a wipe-on product, no rubbing or buffing or pressure is needed. I used to work for a company that sold General Finishes products, and the factory Rep told me that 75% of the time, that’s what causes the white spots. Good luck.
