| Forum topic by jimmac | posted 499 days ago | 1297 views | 0 times favorited | 18 replies | ![]() |
499 days ago |
Topic tags/keywords: finishing shellac techniques Anyone ever use a rub on (with a pad) method of applying shellac? What is the best technique to use? Any pitfalls to avoid? jimmac -- James Mack |
18 replies so far
#1 posted 499 days ago |
Jimmac—Yup … I wipe shellac (1 pound cut) on with a lint-free rag all of the time. Thin coats, one or two quick passes per coat, and scuff with 400-grit or steel wool between coats. Avoid the temptation to flood it on and keep moving. Remember that subsequent coats of shellac dissolve the earlier coats, so if you over-do it with the cloth or put too much on, you can wind up with a mess. —Gerry -- Gerry -- "I don't plan to ever really grow up ... I'm just going to learn how to act in public!" |
#2 posted 499 days ago |
I sounds like you are using the shellac just to lock your stain and grain filler in place before you topcoat - If you are worried about getting a smeary mess I would spray the shellac – especially if there are a lot of corners and fluted columns to get into. To Jims point – you also can fix shellac if you get a sag or problem using a clean rag with alcohol – you can relevel the surface Do you brush or spray your lacquer?
I like it because it has a lot of retarder in it to slow it’s drying and is a lot higher viscocity, so it rarely runs -- "_If we did all the things we are capable of doing, we would literally astonish ourselves_." Edison |
#3 posted 499 days ago |
I use a rubber with shellac usually. I rarely brush it. You still |
#4 posted 499 days ago |
Loren: Jim -- James Mack |
#5 posted 499 days ago |
DrDirt: Jim -- James Mack |
#6 posted 499 days ago |
You have really touched a bright spot in my finishing process ‘cause I really like using shellac. There is a wealth of info available if you’re willing to search. Wiping shellac uses a pad of soft, lint-free cotton filled with a ball of cheese cloth (or other absorbent material), called a rubber, and lubed with mineral oil. Look up wiping finishes-shellac for an extensive source. -- bill@magraphics.us |
#7 posted 499 days ago |
Kinda curious about that myself too Jim. Edit: Oh, I see Bill has answered the question. Sounds a LOT like a french polish. -- Backer boards, stop blocks, build oversized, and never buy a hand plane-- |
#8 posted 499 days ago |
Jim - When I french polished (twice ever) we had a cheese cloth surface around a wad of wool – a piece of a boot liner (Sorel for all the folks in northern climates) Making a Polishing Rubber Polishing Cotton 100% (lint free) Tear off a 6-9 inch square of cotton wadding and fold it in half, fold the corners of the rectangle to form a triangle -- "_If we did all the things we are capable of doing, we would literally astonish ourselves_." Edison |
#9 posted 499 days ago |
Next time I do the shellac thing, I promised myself to (keep using the seal-coat stuff, and) buy good flakes, and mix them with denatured alcohol, for the project, rather than buy the pre-mix stuff. Rumor has it, the result is much longer shelf life, and a better quality product, where you pick the “cut” of the mix. Good source, so I’m told: http://shellac.net/ [forgive them their website. We’re not all IT geniuses !] -- -- Neil |
#10 posted 499 days ago |
Not exactly into the “french polishing” process, though it would be a next step. Just an easy wipe on finish. -- bill@magraphics.us |
#11 posted 499 days ago |
The French polishing is a bit fussy to get going as you use rottenstone and some mineral oil – I found it frustrating and that was just doing panels flat on the workbench – never mind trying to do the side of a highboy, or a surface with a lot of contour. -- "_If we did all the things we are capable of doing, we would literally astonish ourselves_." Edison |
#12 posted 499 days ago |
I usually collect up a bunch of lac bugs, flip ‘em over and pick out the females and then squeeze the stuff right out of their butts onto my project. I love that fresh shellac smell… -- It's the best woodworking show since the invention of wood... New episodes Wednesdays at: http://www.stumpynubs.com |
#13 posted 499 days ago |
I love using shellac and have always put it on with a lint free cloth. I mix mine with flakes, and learned a lot from a Fine Woodworking magazine on Finishing last year. |
#14 posted 497 days ago |
One extra step I was taught was to use a squeeze bottle to apply the shellac to the pad. Every few passes apply a little more. This helps control the amount going on the wood. Also, as the pad starts to stick, squirt some denatured alcohol from another squeeze bottle on the pad as a lubricant. It does not take much of either. Between coats wipe the wood down with mineral spirits and sand with a 600 grit wet/dry sand paper. The one place I still have a lot of problems is getting in the corners. The pad won’t reach, and if you brush it in, it gets thick or runs. Any tips on this? -- Jim, SE Tennessee, "Don't spare the kindling Dear, we have plenty" |
#15 posted 497 days ago |
squeeze bottle also prevents cross contamination from the pad to the reservoir Corners? Cotton tip applicators, Wood block shaped to just get in the corner with cloth wrapped around it, tiny artist brushes. -- When the moderator chooses sides, his site sucks. |
| Forum | Topics |
Woodworking Skill Share
8784 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1522 |
3542 |
15755 |
Hand Tools
2029 |
Jigs & Fixtures
494 |
Wood & Lumber
2833 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2737 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
