Using Bamboo
Forum topic by BentheViking posted 503 days ago 2073 views 0 times favorited 20 replies Add to Favorites Watch
View BentheViking's profile
BentheViking
1135 posts in 733 days
503 days ago
Topic tags/keywords: bamboo
I work at Lumber Liquidators and we sell quite a bit of bamboo floors. Just wondering if any one out there has used bamboo in any projects. Where have you found it to use? Was it just flooring boards that you used in a project or was it regular lumber? Just wondering how it works or if anyone has any thoughts on using/obtaining bamboo that is not flooring.
-- It's made of wood. Real sturdy.--Chubbs Peterson
20 replies so far
87188 posts in 1746 days
#1 posted 503 days ago
http://lumberjocks.com/projects/50343
View richgreer's profile
richgreer
4474 posts in 1244 days
#2 posted 503 days ago
If you go to my workshop pictures you will see the workbench I made with a bamboo flooring top. I’m very happy with it.
I don’t have a picture, but I once made a clock with bamboo.
The only bamboo I have used is left over flooring. The only issue is that, IMO, you have to hide the edges. The top surface has been well treated and has a great look. The back and edges do not have that same look.
I think bamboo is a great product to work with in some applications. It is very tough and durable.
We have over 1000 square feet of bamboo on floors in our home.
I don’t know this as a fact, but it seems like bamboo is less likely to move with changes in temperature or humidity. I’ve never notices a problem with our flooring or the work bench top.
BentheViking
#3 posted 503 days ago
Rich I’m glad to hear that you like your bamboo so much. Judging from your work bench it appears you have horizontal natural bamboo which like vertical bamboo is softer than red oak, though is significantly better than RO in terms of its stability. stranded bamboo on the other hand is roughly 2x as hard and stable as RO. Looking at end grains of vertical and horizontal bamboo you can see that they are an engineered/laminated product. When you have stranded bamboo it looks much more like a solid product and you would probably not have any issues in terms of a bad look on the edge to hide.
Still seems like everyone is just re-purposing flooring. I looked up bamboo on wikipedia. there was a section about using it in construction and furniture, but i didn’t see much info that was too helpful. I wonder if it is readily available as lumber in asia? Any asian LJ’s out there? What about californianians? if anyone domestically could get it I bet it would be them.
View usnret's profile
usnret
185 posts in 677 days
#4 posted 503 days ago
I made some cutting boards from 1” bamboo that was used for stair treads that are not finished. It looks really good. Machines easily and sands pretty good. I also put in a bamboo wood floor that looks really nice.
-- Chief Petty Officer USN(RET) 1991-2011
View 000's profile
000
3352 posts in 786 days
#5 posted 499 days ago
Some folks say it’s “green” because it grows like a weed but I wonder about all the glue one has to use to make boards from it.
-- When the moderator chooses sides, his site sucks.
BentheViking
#6 posted 499 days ago
horizontal and vertical bamboo is laminated so it probably uses a fair amount of adhesive. stranded is shredded bamboo that is boiled down, but I’m not sure if it dried out into a solid or if they use some sort of adhesive to hold it all together.
View 000's profile
000
#7 posted 499 days ago
It won’t glue itself.
View funchuck's profile
funchuck
99 posts in 1226 days
#8 posted 499 days ago
I used bamboo to make fly fishing rods before. You have to be prepared to get a lot of nasty cuts though. For some reason, it takes a little longer for them to heal. I bought actual bamboo (not the flooring). They were around 3” diameter, and I split it lengthwise so I had 8 (I think) full length pieces. Then, I used a block plane to get them to the desired dimension.
The bamboo is pretty thin (about 1/4” to 3/8”), so you’ll probably have to layer them or something, if you want to build furniture, or, maybe use it like a veneer. I got my bamboo from butler bamboo in Santa Ana, CA. Since I work near there, I got to hand pick it too.
-- Charles from California
BentheViking
#9 posted 493 days ago
guess this is answering my own question a bit but I was just watching house crashers on HGTV and came across this company called teragren that makes a ton of bamboo products (all in the us of a). looks like mostly they do flooring, panels, coutertops, and veneers. but on the show they made a slat accent wall using a panel cut down into strips. I’m sure they are probably pretty expensive and crazy heavy, but hey im sure we’ve all used expensive and heavy materials before. At least its environmentally friendly! Also it appears as if they have access to dealers in most parts of the country for anyone that might be interested
I do have to say though I have been wondering a number of my original questions regarding locating and or using eucalyptus since we recently started selling a few floors made from that.
View Tokolosi's profile
Tokolosi
616 posts in 524 days
#10 posted 493 days ago
I have experimented with some bamboo floor salvage. I probably did something wrong (or had the wrong blade) – but all the pieces I cut burned so bad on the edges that they were unusable. Smells really good when it burns though.
-- “There is nothing like looking, if you want to find something. You certainly usually find something, if you look, but it is not always quite the something you were after.” ~ JRR Tolkien
View Clint Searl's profile
Clint Searl
848 posts in 530 days
#11 posted 493 days ago
The tops, sides, and backs of these pieces are 1/2” T&G bamboo flooring.
-- Clint Searl.............We deserve what we tolerate
BentheViking
#12 posted 493 days ago
clint bamboo or not that is an awesome piece both in design and execution. what are the other woods that you used?
Clint Searl
#13 posted 493 days ago
@Chubbs – Thanks for the compliment. The frame is dye stained red oak, the upper drawer faces are spalted maple, the lower drawers are spalted beech, and the slider panel is patinated copper. The finish is NC lacquer.
View Tomj's profile
Tomj
197 posts in 551 days
#14 posted 492 days ago
I have used bamboo in bows. I got into woodworking making bows/ laminated bows/selfbows etc.. I agree with everything you Bentheviking said. When it comes to making bows bamboo is considered natures fiberglass. It is very strong in tension (works well on the back of bow) and not so much in compression. Just like different woods have different strengths same goes for bamboo. Some bamboo I wouldn’t use for furniture and especially not for bows. I have never made any furniture with bamboo though I know the Japanese prefer to use Madake A.K.A Japanese Timber Bamboo for furniture (grows to 72’ and 5-6” in diameter) it is very strong and easy to work with because it tends to grow very strait. The second that is usually used in bamboo flooring is “Moso” it is the largest of any bamboo growing to 75’ tall 7-8” in diameter. It is also the bamboo typically used for scaffolding. Bamboo does like to suck up moisture it needs to be sealed well. I myself have some Japanese timber bamboo growing in the backyard, although it most likely will not grow to it’s 72’ because of the climate here on Long Island.
View MrsN's profile
MrsN
917 posts in 1695 days
#15 posted 492 days ago
I have made some cool things from pre-made bamboo cutting boards. The HomeGoods sore near by was clearancing out a bunch and I bought them all for way less then a piece of oak that size.
I just looked to see if the projects had been posted here, but I haven’t posted them.
Here they are
-- ----- www.KNWoodworking.com ----- --
