12 in scms blade wobble?
Forum topic by Havasumatt posted 01-05-2012 03:18 AM 1426 views 0 times favorited 6 replies Add to Favorites Watch
View Havasumatt's profile
Havasumatt
30 posts in 2438 days
01-05-2012 03:18 AM
Topic tags/keywords: scms wobble arbor wobble blade wobble miter saw blade
Hello fellas! I got a 12 in crftsmn scms that wobbles a little much. Thought it was the crap blade it came with so swapped it with a Forrest chopmaster. Assuming the Forrest isn’t bent, the saw wobbles. It’s a 5/8 arbor but with a 1 in adapter washer type that goes in the blade. Anyone have any ideas on what to try and fix this problem? Don’t have a dial gauge but would say the wobble is around 1/8 inch at least. Still cut pretty clean with the Forrest but not what I believe it should with plywood with minor splintering.
View cabmaker's profile
cabmaker
1738 posts in 2895 days
#1 posted 01-05-2012 04:02 AM
Could be bent arbor or ? Are you saying that that saw has a 5/8 arbor. Never heard of that on a 12 inch saw.If that is the case that may be the problem. thats not much arbor to support a large plate blade. Is your seating area clean ?
Havasumatt
#2 posted 01-05-2012 04:17 AM
Yeah the crftsmn has a 5/8 arbor. There’s a reducer that goes in the hole on the blade that makes it 1 in. down to 5/8. Every thing is clean. Maybe something needs replaced, just not sure where to start.
cabmaker
#3 posted 01-05-2012 04:57 AM
Good luck with it. I wouldnt know where to look other than worn arbor bearings and or bent arbor. It doesnt take much of a kink to wobble a blade. Is your bolt,(nut,washer combo) covering the full perimeter of your 1 inch bushing when tightened?
Havasumatt
#4 posted 01-05-2012 11:47 PM
Yeah everything seams flush and good. Wouldn’t think it would cost much to start changing out everything form the bolt, washer plates and the other parts. If anyone knows a different way it would be appreciated. Guess I should have spend a couple more hundred for a better brand! Thanks for the replies though!
View Bill White's profile
Bill White
5011 posts in 4046 days
#5 posted 01-06-2012 12:55 AM
Congrats on the C’man. Don’t wanna seem a pooper, but there ya go.
Bill
-- bill@magraphics.us
View StumpyNubs's profile
StumpyNubs
7636 posts in 2886 days
#6 posted 01-06-2012 01:03 AM
I sould start with that reducer. Is it machined or stamped? Try and check to make sure it is flat. Maybe put it on without the blade and see if you can measure any wobble in it.
I figure you gotta start somewhere, and that would be the cheapest fix if it is the problem.
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications: http://www.stumpynubs.com/
