Need HELP finding a sander for Curves!
Forum topic by Ryan Haasen posted 01-05-2012 12:45 AM 1679 views 0 times favorited 7 replies Add to Favorites Watch
View Ryan Haasen's profile
Ryan Haasen
385 posts in 2522 days
01-05-2012 12:45 AM
Topic tags/keywords: question sander guinevere sanding system
s
I am in the planning process of building a model Bell 407 Helicopter for my dad. It will be about 46” long and has a bunch of curves that have to be perfect, and my stationary sander won’t do the trick. I have looked on the internet and have come across the Guinevere Sanding System. It looks like the perfect tool for the job but it costs a lot. Is there a something that will do the same thing for a lower price or is the Guinevere the way to go? I prefer a hand held device because it will be too difficult to manoeuvre this hunk of wood around a stationary sander.
Thanks in advance for comments and suggestions.
-- Ryan
7 replies so far
View CalgaryGeoff's profile
CalgaryGeoff
937 posts in 2603 days
#1 posted 01-05-2012 01:09 AM
How about a hand held dremel with a sanding disk. Mine works well and has a cable extension off the dremel like a dentist drill giving it a lot of flexibility and ability to sand exactly where you want. Good luck and awesome work.
-- If you believe you can or can not do a thing, you are correct.
View DS's profile
DS
2979 posts in 2542 days
#2 posted 01-05-2012 01:13 AM
Then there’s the ever trusty hand held piece of folded sandpaper! heheh.
View dorielwooden's profile
dorielwooden
79 posts in 2808 days
#3 posted 01-05-2012 01:46 AM
Hi, in my order is almost the same model that I have to build, there are two ways to build one piece of wood and another to build parts and glue.
-- What I can do with a piece of wood and mine or your imagination. http://dorielwoodenscollections.blogspot.com
View Loren's profile
10477 posts in 3769 days
#4 posted 01-05-2012 01:52 AM
You can buy the system without the motor and flexible shaft…
but it’s still spendy for what you get.
Buy let me Google that for you:
http://www.google.com/search?q=bowl+sanding
View SnowyRiver's profile
SnowyRiver
51457 posts in 3602 days
#5 posted 01-05-2012 01:53 AM
I use my Dremel like GalgaryGeoff mentioned. I have a set of sanding drums that I usually use in the drill press, and they fit the Dremel just fine. It makes a great hand held sanding machine.
-- Wayne - Plymouth MN
Ryan Haasen
#6 posted 01-05-2012 01:54 AM
Thanks for your suggestions, The dremel is a great idea, as well as what Loren mentioned. And hand sanding will always be the finishing touch!
-- Ryan
View toymaker's profile
toymaker
66 posts in 3918 days
#7 posted 01-08-2012 04:25 AM
you can get the Dura grit bits for your dremel and they work great i use them all the time for things on my projects. i got mine from Lee Valley tools.
