Wood Filler
Forum topic by richgreer posted 01-04-2012 07:19 PM 7858 views 0 times favorited 27 replies Add to Favorites Watch
View richgreer's profile
richgreer
4541 posts in 3314 days
01-04-2012 07:19 PM
First, let me say, that I really don’t like to use wood filler. When I use wood filler, it is because I did not get the tight joint I was striving for. Nonetheless, I need to use at least a little wood filler on many of my projects.
Originally, I used a brand called Famowood. I didn’t like the fact that I usually had to stir it before using it and I didn’t like the fact that it tended to dry out in the can quite quickly. What I liked is that it dryed very quickly after being applied. I could sand it within 30 minutes of when I applied it.
My second brand was Elmer’s, which comes in a plastic tube. It does not have to be stirred. I think it is a little easier to work with. It also dries out in the tube, but at a slower rate than the Famowood. After applying it, it takes at least an hour before you can sand.
Lastly, I tried a can of MinWax. I found it hard to apply and I had to wait until the next day to sand it. I don’t know fast it will dry out in the can since I just bought my first can of it. Note – MinWax calls their product “Wood Puddy” as opposed to “Wood Filler”.
At this point in time, Elmer’s is my favorite of the 3.
How about you?
27 replies so far
View Ripthorn's profile
Ripthorn
1459 posts in 3224 days
#1 posted 01-04-2012 07:22 PM
I am not a huge fan of Elmer’s, but have not tried the other two. I have used Timbermate and quite like it. It’s water-based, so if it dries out in the can, mix in some water. If it freezes, thaw it in the mircrowave and mix in some water if necessary. It works very nicely.
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2594 days
#2 posted 01-04-2012 07:30 PM
I use Pl Woodpatch which is very similiar to the famowood, cept it’s just better…
You don’t have to stir it as much though, if you store the cans upside down, flipping over a few minutes before you use it. They are a two part mixture that seperates in the can. The heavier filler will settle to the bottom, while the lighter catalyst will settle to the top, when you flip the can, it causes the two to re-mix by their natural settling motion.
Bad joints aren’t the only reason to use wood fillers, sometimes it’s good to fill those defects in the boards, or just flat out highlight what you know you’ll miss when sanding.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
richgreer
#3 posted 01-04-2012 07:44 PM
TCC – You are right about needing wood filler for applications other that joints. Just yesterday a pocket hole screw went all the way through the wood. I backed it out, replaced the screw with a shorter one and used wood filler to fill the hole.
It was not a typical joint issue but I was still using filler to hide a mistake.
View Dan's profile
Dan
3630 posts in 3120 days
#4 posted 01-04-2012 07:54 PM
Rich, is Minwax “Wood Puddy” the same as the Minwax “Wood Filler”?
I am pretty sure they are different but I have never used the Wood Puddy so I don’t know.
I use the Minwax Wood Filler and I find it to work rather well. It will bleed into the wood so I usually tape off around the area I need to fill. Dry time will depend on the amount that you use but I know the last time I used it was to hide a bunch of nail holes and I was able to sand it after a couple hours.
-- Dan - "Collector of Hand Planes"
View Gene Howe's profile
Gene Howe
11161 posts in 3668 days
#5 posted 01-04-2012 07:58 PM
Another satisfied Timbermate user, here.
View Bill White's profile
Bill White
5149 posts in 4200 days
#6 posted 01-04-2012 07:58 PM
TimberMate is great stuff, and beats the heck outa MinWax.
Bill
-- bill@magraphics.us
16281 posts in 4458 days
#7 posted 01-04-2012 08:27 PM
Believe it or not, I use all three of the types you mention, Jim. I find they all have pros and cons… it just depends on the particular situation.
The Elmer’s also comes in a tub, and you can add a little water when it starts to dry out.
View ChunkyC's profile
ChunkyC
856 posts in 3493 days
#8 posted 01-04-2012 08:29 PM
TimberMate.
Pricey but well worth it.
c
-- Chunk's Workshop pictures: http://spadfest.rcspads.com/thumbnails.php?album=135
View NiteWalker's profile
NiteWalker
2738 posts in 2816 days
#9 posted 01-04-2012 08:32 PM
I’ve been using water based famowood and it works great for me. No drying issues for me, but even if it did, you can add a bit of water to renew it.
I plan to try the timbermate very soon.
I used elmer’s a long while back on painted projects and it worked fine. Availability is it’s strong suit.
View Don Johnson's profile
Don Johnson
704 posts in 3020 days
#10 posted 01-04-2012 09:19 PM
Over in the UK when I was a lad, THE product was Brummer
It is still around, and (before the tin dries out) is very effective and fast drying – in minutes not hours.
I think it needs cellulose thinners – or something similar – to moisten it, but I await correction.
Certainly, water ruins it!
-- Don, Somerset UK, http://www.donjohnson24.co.uk
View Sawkerf's profile
Sawkerf
1730 posts in 3308 days
#11 posted 01-04-2012 09:49 PM
I use Famowood and will sometimes mix colors to get the shade I need. A bit of Acetone stirred into the can brings it back to like new.
View Don Niermann  's profile
Don Niermann
219 posts in 4212 days
#12 posted 01-04-2012 09:52 PM
Hide glue and sawdust
-- WOOD/DON (...one has the right to ones opinion but not the right to ones own facts...)
View bobasaurus's profile
bobasaurus
3549 posts in 3423 days
#13 posted 01-04-2012 09:57 PM
I use either DAP Plastic Wood, or just regular Titebond glue mixed with sawdust (sometimes I just smear the dust in with my finger after spreading glue over a crack/gap/etc).
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View Dennis Fletcher's profile
Dennis Fletcher
467 posts in 3294 days
#14 posted 01-04-2012 10:00 PM
Hmmm, I prefer the Elmer’s wood filler that you get in the little canisters. It goes on easily, dries quickly and doesn’t seem to dry out in the container.
I often use it when i do “paintable” trim work, where I just need to fill in holes or such. I have also used it for repairs, when a chunk of wood has been broken off. I will glue it back on and reshape the area with it, then sand it to the correct shape.
Works really well for me.
The minwax wood putty I use doesn’t get hard. It is used to fill in after the stain and such is on. It is meant to cover up nail holes and such and blend in with the color.
-- http://www.ahomespecialist.net, Making design and application one. †
View Woodwrecker's profile
Woodwrecker
4211 posts in 3815 days
#15 posted 01-04-2012 10:09 PM
Minwax wood filler.
I don’t like using it either, but sometimes it’s unavoidable.
Good topic Rich.
