Looking for a detail sander
Forum topic by KenBry posted 01-04-2012 04:21 AM 2654 views 0 times favorited 11 replies Add to Favorites Watch
View KenBry's profile
KenBry
481 posts in 2356 days
01-04-2012 04:21 AM
I was wondering what you guys like to use for detail sanders. I got the fein Multimaster for Christmas. It looks like it has potential for detail sanding. Just wondering what else I should consider.
-- Ken, USAF MSgt, Ret.
11 replies so far
404 - Not Found
2544 posts in 2878 days
#1 posted 01-04-2012 05:46 PM
You will definitely be able to put a delta head on that – wasn’t there one in the box? I have a different multitool model and that has the triangular hook and loop head, sands into corners well.
View richgreer's profile
richgreer
4541 posts in 2983 days
#2 posted 01-04-2012 06:31 PM
My multitool, Rockwell, has the triangle sanding head and an even smaller head that really gets into tight places.
View Jim Finn's profile
Jim Finn
2622 posts in 2830 days
#3 posted 01-04-2012 11:00 PM
I once had a Bosch detail sander but found it tiring to use. I like a small sander where my hand is over the sandpaper not a foot away as on the Bosch.
View Dan's profile
Dan
3630 posts in 2789 days
#4 posted 01-04-2012 11:03 PM
I have a couple detailed power sanders and they work great but I personally find it easiest to do detail sanding by hand. Its not really that much more work then handling the power sander.
-- Dan - "Collector of Hand Planes"
View Gene Howe's profile
Gene Howe
10136 posts in 3337 days
#5 posted 01-04-2012 11:13 PM
Take a look at Dremel’s detail sander.
View Domer's profile
Domer
252 posts in 3275 days
#6 posted 01-05-2012 12:49 AM
I have owned a bunch of detail sanders, Dremel, Porter Cable, Rigid and Black and Decker Octo. Probably some more. I was trying to find a cheap alternative. And as usual, when I try to cheap out, I am mot very satisfied. The Dremel was the least expensive and worked better than any of the other inexpensive sanders. However, I eventually could not find the sanding pads and belts.
Fein has a sanding accessory that has the delta shaped head and also has the detail sander attachment with a number of different sized and shaped heads. The different shaped heads use regular sandpaper which you clamp into the fixture head. It is by far the best I have found so far.
It is not inexpensive but I probably spent close to as much trying different inferior detail sanders over the years as I spent on the Fein.
Festool has a new sander out that has a delta head as well as a small random orbit sander but it is almost as much as the Fein with all of the options.
I did not try the Bosch or Rockwell. The Bosch got pretty good reviews.
However, if you already have the Fein power head, I would look at the detail sander attachment for it. It is a great tool.
Domer
View live4ever's profile
live4ever
983 posts in 2919 days
#7 posted 01-05-2012 01:31 AM
Depends what you mean by detail sander.
If you are looking for a sander with a small [delta] head that can get into corners for occasional use, the Fein MM will probably do ok for you. But if you expect to use it as a fine woodworking detail sander, you might be disappointed. It’s great for restoring and repairs.
The Festool RO90 is a little bit better than the Fein as a sander, IMHO. It costs more than a Fein with all the fixin’s. However, its rotary mode also gives you a very aggressive sander and a pretty decent polisher, albeit with a small head (3”). It’s a very versatile sander. Festool makes a variety of accessory pads for it…as a system it is very nice but expensive. Festool sandpaper doesn’t cost that much more than non-Festool and it’s pretty good stuff. They also offer a 30 day no questions asked return policy…don’t like it, return it. Note that the Festool slope is a really, really slippery one.
I look at it this way…the Fein is a multitool that CAN sand decently in a pinch, but it will leave marks. The dust collection accessory does work and catches maybe 75% of the dust. The Festool RO90 is a sander with fantastic dust collection that can do a lot of different sanding operations quite well.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3389 days
#8 posted 01-05-2012 01:56 AM
I have an older Fein detail sander and it works great.
-- Wayne - Plymouth MN
View b2rtch's profile
b2rtch
4847 posts in 2957 days
#9 posted 01-05-2012 01:27 PM
For $19.00 on sale the Harbor Freight one works perfect.
-- Bert
b2rtch
#10 posted 01-05-2012 01:30 PM
Domer However, I eventually could not find the sanding pads and belts.”
Klingspor will make any custom belt or pad for you for a very reasonable price.
I buy all my abrasive product from them and I am extremely satisfied
http://www.woodworkingshop.com/
-- Bert
404 - Not Found
#11 posted 01-05-2012 03:39 PM
