How to lube bearings on circular saw?
Forum topic by Loren posted 01-04-2012 02:16 AM 3537 views 0 times favorited 4 replies Add to Favorites Watch
9931 posts in 3549 days
01-04-2012 02:16 AM
I have this little old Makita trim saw with a brake. Not a bad
saw ‘cept it was used to cut stone and has slurry all over it.
Finally I used a “Shark” steamer get the guard parts unfrozen,
but I blasted the lube out of the bearings too…
The dumb thing was buying this thing in the first place
and thinking the grime wouldn’t be a problem. Anyway,
is there a way to get the bearings running smoothly again
or do I have to replace them?
View Mickey Cassiba's profile
Mickey Cassiba
312 posts in 2933 days
#1 posted 01-04-2012 02:21 AM
The bearings in most portables are sealed. If you ‘blew the lube’ out of it you likely compromised the seals as well. Any attempt to re lubricate them will be short term. The good news is that most bearings used in small tools are easily found at a bearing supply. The bad news is the old ones can be a bear to remove/replace.
Good luck.
-- One of these hammers oughta fix that...
View Grandpa's profile
Grandpa
3259 posts in 2577 days
#2 posted 01-04-2012 06:45 AM
Replace them. They should be readily available and not difficult to replace unless they are stuck on a shaft. Get a good puller and you shouldn’t have too much of a problem. Good Luck
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2256 days
#3 posted 01-04-2012 07:04 AM
The bearings should be sealed. I’d put some white lithium grease on it to see if that helps though just the same, if not, new bearings.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
View Lee Barker's profile
Lee Barker
2170 posts in 2752 days
#4 posted 01-04-2012 07:06 AM
Do you want to cut your losses, Loren? You don’t sound exactly head over heels over this tool.
If it does have a place in your heart and in your shop, take it to the Dr. and have it fixed right and enjoy it!
I have a hunch you will have invested less than a new one. And older stuff is better, right?
Kindly,
