Delta Super Ten (34-740) Tablesaw & Delta T2 Fence Retrofit
Forum topic by Nodak7mm posted 502 days ago 1057 views 1 time favorited 5 replies Add to Favorites Watch
View Nodak7mm's profile
Nodak7mm
21 posts in 719 days
502 days ago
Topic tags/keywords: tip
Would like to say thanks to all the folks here who have previously installed the Delta T2 fence system on their saws, specifically the saws that did not permit instant boltup and fittings.
Even though my saw is a Delta, it didn’t mean it was to fit right up. First thing I found out was that there is the standard table saw depth of 27”, this appears to be commonly called a contractor saw and I figured thats what I had.. Not to be, my Delta 34-740 has a table depth of 22”.. Secondly the bolt holes did not even remotely come close.
So whats a guy to do, after he already bought the T2 fence?? Hmm, after alot of research via this forum and the rest of the internet, combined with a call to Delta Tech services, I figured that I could make it fit and work..
That it did….. I finished my install today, it works mint and I am here to say; I am really glad I made it work. Sure do love the thing..
Well the Delta T2 fence info was sure lacking on models it fits. But with a little bit of inginuety, careful measuring, drilling & easy relocation of a key component. It works as advertised.. All I had to do was find “Zero” on the tabletop, redrill new holes in both mount rails and then move the rear clamp in 4.75” & remount it…
Awesome fence for the money!!
Rod V
-- You need to try everything to honestly evaluate anything.... Anonymous
5 replies so far
View knotscott's profile
knotscott
4185 posts in 1542 days
#1 posted 502 days ago
Pics?
Nodak7mm
#2 posted 502 days ago
Thought about that when writing the post, at the time I figured there were quite a few pix of this fence available. If anything in particular you would like to see, I would be glad to take pix and post.
Rod V
knotscott
#3 posted 502 days ago
Rod – Yours is the first post where I’ve seen someone add this fence to that saw, or even this type of saw….the vast majority are full size 27” deep saws. It’d be really helpful to others if you could post some pics of the installation.
View roguefate's profile
roguefate
1 post in 367 days
#4 posted 367 days ago
Hello Rod!
Please help out a guy who’s in the EXACT same situation that you’re talking about here. I really need to understand what you had to do in order to make this fence work with a 22” deep Super Ten 34-740. Could you provide me with MORE DETAILED information on this installation procedure? I’m stuck and need to make these 2 pieces of equipment work well together.
Thank you!
ChrisG
Nodak7mm
#5 posted 367 days ago
Chris,
Private message sent…
Rod
