| Forum topic by Bill Hall | posted 564 days ago | 257 views | 0 times favorited | 6 replies | ![]() |
564 days ago |
564 days ago |
Cheaper water stones are most likely not going to be “pretty decent”. You get what you pay for. My advice: Save up a bit more and buy the Nortons. You won’t be disappointed. I think most people spend way too much on sharpening equipment, but it isn’t because they spend a lot of money on one particular system or method. It’s because they’ll buy oil stone and try them a bit, but they won’t be happy with the results so then they’ll buy water stones and try them a bit. When they aren’t happy with THOSE results, then maybe they’ll pick up some ceramic stones or go the Scary Sharp method before buying one of those expensive sharpening systems. Try one route and stick with it for a while until you really get the hang of it. And when you get frustrated, just stick with it a while longer. It can take some time and a lot of practice to get good at sharpening. Oh, you might want to also pick up Robin Lee’s book or Thomas Lie-Nielsen’s book on sharpening – both have been rated as some of the best sharpening info you can read. Oh, and don’t skimp on the stones. Nortons cost a littel more, but they’re consistent throughout (i.e. man-made) and worth it. -- Ethan, http://greystonegreen.blogspot.com/ |
564 days ago |
Bill. Are you looking at the combo Norton stones? If you go that route, it’s only two stones to buy (plus you’ll want something on which to flatten them). I’ve had those for quite a while now, and they still have a lot of life in them. They are the only thing I use to sharpen my chisels and planes. -- johnjoiner |
564 days ago |
I would recommend a diamond stone, will cost more but last longer & give you better results, does for me anyway. -- Grumpy - "Always look on the bright side of life"- Monty Python |
564 days ago |
I recently bought a King water stone at Woodcraft. It has 2 grits, one on each side. I’m slowly getting better with sharpening and it takes some time. I’d also suggest a honing guide (~$10-15) and a flattening stone (~$20). -- Paul D, Atlanta GA |
564 days ago |
I got the Kings from Woodcraft, same as Paul D – two-sided. One is 800/4000 and the other is 1200/8000. Also got a nagura stone which you have to have with any stones at 6000-grit or higher. And like Paul, I also got the honing guide. -- Eric at http://adventuresinwoodworking.com |
564 days ago |
I thought I could get a good edge on chisels, plane blades etc until I tried using the combo waterstones from LV. Man! night and day difference on the resulting edge. Imagine using a table knife and then switching to a filleting knife for filleting a fish…that kind of difference. Jenn bought me the LV sharpening guide and the 1000/4000 waterstones and I am extremely happy with them. In fact I was just working on a chisel for a buddy of mine and really enjoying what a keen edge is developing on the chisel. -- ...it's rennovation time!!! |
| Forum | Topics |
Woodworking Skill Share
2928 |
3961 |
258 |
955 |
226 |
Woodworking Trade & Swap
623 |
Coffee Lounge
2398 |
LumberJocks.com Site Feedback
524 |
