Pop Quiz - How would you make this cut?
Forum topic by live4ever posted 01-02-2012 08:50 AM 2060 views 0 times favorited 45 replies Add to Favorites Watch
View live4ever's profile
983 posts in 2944 days
01-02-2012 08:50 AM
In the shop we are often faced with a task and multiple ways to perform the task. That decision point, which we go through tens of times every day in the shop, can have huge implications not just for the satisfactory result of the task but also our safety.
I recently had the simple decision of how to do the following and I’d like you to choose your own adventure. How would you do it in your shop with your tools?
You want to 45-degree bevel one edge of a 3/4” thick 2×2” workpiece.
NOTE: Try not to look at other responses before you answer. Just ask yourself how you’d do it and post your reply. If you just agree with another poster it’s really no fun.
As Charlie points out, I left out a key detail – the depth of the cut is all the way through the 3/4”, as in making a mating bevel on a french cleat block.
45 replies so far
View derosa's profile
1572 posts in 2770 days
#1 posted 01-02-2012 08:53 AM
I would cut that on the bandsaw. Being that small I might try the scroll saw but I don’t know if it goes to that angle. Bandsaw seems safest otherwise.
-- --Rev. Russ in NY-- A posse ad esse
View David Grimes's profile
David Grimes
2078 posts in 2574 days
#2 posted 01-02-2012 10:47 AM
I would tilt the bed on the Ridgid sander to 45 degrees, slide the miter gauge into the track (to give me something to hold it against straight), then gently feed it into the belt until I see it reach the top corner. Total time about 30 seconds. Fingers (and the skin that covers them): intact.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
View Nighthawk's profile
554 posts in 2291 days
#3 posted 01-02-2012 10:50 AM
Depends on the wood hard or softwood… but most likely I would go to the band saw (if I had one…) but in this case since that it is still on my wish list (but hopefull for not to much longer… the scroll saw would also work… being so small a cut possible hand cut it… but it depends what the part was for and how accurate I have to be with the cut.
However I would have most likely put the bevel on it before it was cut down to (converting imperial to metric and back again) ermmmm size and most likely on the table saw with a jig or even mitre saw, and then cut my shape…
-- Rome wasn't built in a day... but I wasn't on that job? ...
View Gary's profile
9312 posts in 3367 days
#4 posted 01-02-2012 11:21 AM
I have a sliding jig I use on the TS for small cuts. Guess I’d use that
View miles125's profile
2180 posts in 3940 days
#5 posted 01-02-2012 12:00 PM
I’d do the bevel on the jointer to long lengths before ever cutting them into 2” long pieces.
-- "The way to make a small fortune in woodworking- start with a large one"
View Gene Howe's profile
Gene Howe
10260 posts in 3363 days
#6 posted 01-02-2012 03:20 PM
Router table, long stock (or a small parts holder) and a 45 bevel bit.
View Alan Robertson's profile
Alan Robertson
66 posts in 3853 days
#7 posted 01-02-2012 03:21 PM
Table saw.
-- MrAl
15249 posts in 2553 days
#8 posted 01-02-2012 03:24 PM
Mark it with a gauge, plane with a cambered #5 until close, finish with a smoothing plane. 90 seconds or less, no safety concerns.
View bent's profile
311 posts in 3603 days
#9 posted 01-02-2012 03:25 PM
View kizerpea's profile
774 posts in 2302 days
#10 posted 01-02-2012 03:33 PM
table saw…push stick..or custom push board..more than one way to skin a cat!
16273 posts in 4153 days
#11 posted 01-02-2012 03:34 PM
I can’t answer without know how deep of a cut we’re talking about. If it’s fairly shallow, I would do it on the router table with a 45 degree chamfering bit.
View ChuckV's profile
3102 posts in 3461 days
#12 posted 01-02-2012 03:45 PM
If possible, I would have beveled it on the TS before the piece was cut so small.
Otherwise, I would use a hand plane.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
View bunkie's profile
412 posts in 3081 days
#13 posted 01-02-2012 03:50 PM
I would hot-melt glue the workpiece to a longer board and cut it on the tablesaw.
-- Altruism is, ultimately, self-serving
View richgreer's profile
4541 posts in 3009 days
#14 posted 01-02-2012 04:25 PM
Others have said that they would make the 45 cut while the piece were still bigger and cut it down to size later. I agree with that. But sometimes that is not an option. Hence I offer how I would do it if I did not have the option of making the cut earlier.
I would cut a scrap piece of larger wood with a 45-degree angle, clamp that piece to the sled for my TS and clamp the small piece to the scrap block I had made.
Also – by drilling a hole into the scrap piece, I would be able to securely clamp the small piece to the scrap piece using a clamp like this
Note, these clamps are handy for a number of applications other than just adding a sacrificial board to your TS fence.
View PurpLev's profile
8534 posts in 3583 days
#15 posted 01-02-2012 04:30 PM
router table with a 45/bevel cutter and a push block/sled. since it’s just 3/4” thick material this would be the easiest, safest, and cleanest cut
showing 1 through 15 of 45 replies
