Good sources for nightstand design
Forum topic by descout posted 504 days ago 1116 views 0 times favorited 3 replies Add to Favorites Watch
View descout's profile
descout
104 posts in 1261 days
504 days ago
Topic tags/keywords: nightstand drawer build project question
I am looking at building a set of night stands. I have an idea of what I want to build but I have never built anything with drawers. So I would like some good sources where I could look at projects so I can get an idea how to build the drawer and how to build it into the night stand. I have seen plenty of nightstands but I want some sources that actually show woodworking projects so I can get a look at actually making the drawer from a “builders” perspective vs the consumers perspective. Thanks guys!
3 replies so far
View Lee Barker's profile
Lee Barker
1884 posts in 1018 days
#1 posted 504 days ago
A drawer is a drawer. A box that slides into a box.
Can you draw sketches of the side view and front view of the idea, with dimensions penciled in? From there, add some detail dimensions and you’ll end up with your drawer opening.
If you use metal slides, your drawer will be 1” narrower than the opening.
Plan for the box to be 1” shorter than the opening, a quarter at the bottom and 3/4 at the top.
Build the box and add a front.
This will help you develop your drawer “style”. Build one out of scrap wood first, the whole nightstand if you want, and you’ll have fun and learn a whole lot of stuff.
Go for it!
Kindly,
View jusfine's profile
jusfine
2152 posts in 1093 days
#2 posted 504 days ago
Lee laid it out for you perfectly.
There are books @ Fine Woodworking specifically for building drawers, if you want to go that route.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View casual1carpenter's profile
casual1carpenter
250 posts in 643 days
#3 posted 504 days ago
There is a number of drawer methods, the choice depends on the tooling you have and your knowledge / comfort level with them and the method process. Some here do the most amazing hand cut dovetails. Yes they work with tools that you can not plug into the wall or charger. Machine dovetails, box joint, rabbits, etc, saw one guy used biscuits, I guess because he bought one and had to do something with it.
