| Forum topic by willie | posted 506 days ago | 1073 views | 0 times favorited | 22 replies | ![]() |
506 days ago |
Topic tags/keywords: bandsaw
After about a month long search I finally found a bandsaw. It’s a 1956 14” Delta Milwaukee. This thing is built like a tank and in excellent condition. I will want to replace blade guide blocks and I need to find a fence and the rails, but other than a good cleanup and a fine tuning, it’s ready to go. I have not had much luck finding info about this saw online. If anyone knows a site that would help I would appreciate hearing about it. Also if anyone knows where I can find a fence and the rails it mounts to would be nice. Thanks Willie (sorry the picture is sideways, don’t know how to correct) -- Every day above ground is a good day!!! |
22 replies so far
#1 posted 506 days ago |
Congrats on the saw, should serve you well. -- Don, Royersford, PA |
#2 posted 506 days ago |
#3 posted 506 days ago |
Thanks for the link, Loren. That’s it, just like mine. I wasn’t aware of any belt guard. Mine doesn’t have one and I dont even see a place to mount it. Don’t think it’s going to be a problem without it. I’m really looking forward to restoring it. Not much needs done except a good cleaning and a little paint and polish. Tires are good but rubber, guide blocks are original and will be replaced. It even has the original aluminum disc around the blade that’s not all chewed up! I thought the 1/2 hp motor was small but I see that’s what they had when new so I’ll see how that works out. I looked at a lot of new saws and a lot of junk used saws. After I got over the sticker shock of the new ones I figure I got a good deal. -- Every day above ground is a good day!!! |
#4 posted 506 days ago |
The saws were available in different packages, though today |
#5 posted 506 days ago |
I have an old Delta /Milwaukee like that. I’m using the kreg fence. It bolts to the table. I put in cool blocks, but you could make them yourself out of hardwood. Them old bandsaws like that will go on forever, you’ll like it. -- It must be jelly baby, cause jam don't shake like that... |
#6 posted 506 days ago |
I recommend calling Iturra Design (904-642-2802) and getting their catalog. My 2010 fall issue was free. 234 pages of products and advice for 14” bandsaws. -Jack |
#7 posted 506 days ago |
Good find. Clean it up and it will last a lifetime those saws were built to last forever. Russ |
#8 posted 505 days ago |
Mine’s the old Delta with the cast floor model base. Should be able to easily find fence and rails. Mine came as a set. Woodworker’s Supply, Rockler. As hairy said: kreg (a very nice set-up). I like link belts and you may need new tires. Good luck. -- MrAl |
#9 posted 505 days ago |
Hey, according to the picture this is an horizontal band saw. Interesting -- Bert |
#10 posted 505 days ago |
Thanks for all the info. I hope to begin the restoration soon. I’ll post some before and after pics. The guy I got it from was using it to cut metal and has a metal cutting blade and a super small pulley on the motor. This thing runs really slow but I have a larger pulley to put on it and I’ll need to get some blades. What size pulley did they run new? I’ll keep the small one and the blade in case I ever have any metal fabbing to do. All the bearings had been replaced by the previous owner, saves me some work! The tires look pretty new too although they’re rubber. I’ll probably see how it works for now. No vibration, really smooth and quiet. Other than the few things I mentioned all it needs is a good cleaning and a new paint job and it will be better than a new one! -- Every day above ground is a good day!!! |
#11 posted 505 days ago |
Rotate the picture before you post it. -- Dewayne in Bainbridge, Ga. - - No one can make you mad. Only you decide when you get mad - - |
#12 posted 505 days ago |
My motor pulley is a 3”. Upper is 7-3/4”. Make sure you rotate it the right way. Neck is starting to ache. -- MrAl |
#13 posted 505 days ago |
Sorry the picture is on it’s side. It was all I could do to figure out how to get it on this site. -- Every day above ground is a good day!!! |
#14 posted 505 days ago |
On your computer , right click on the image, then edit, then rotate. -- Bert |
#15 posted 504 days ago |
way cool. Isn’t it going to be a little difficult using it on it’s side like that? -- When the moderator chooses sides, his site sucks. |
| Forum | Topics |
Woodworking Skill Share
8792 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1532 |
3549 |
15782 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6158 |
