I don’t think there is an answer to this problem.
Forum topic by doninvegas posted 01-01-2012 01:53 AM 2205 views 0 times favorited 42 replies Add to Favorites Watch
View doninvegas's profile
doninvegas
334 posts in 3143 days
01-01-2012 01:53 AM
I have a Delta contractors saw that I have had for a few years now and it does what I want it to do. But the motor vibrates like crazy. So much so that it has even fallen off. I know that these saws are made to take the motor off for easy transport. I have taken the motor off and reinstalled it a dozen times aligned the pulleys per the manual but it still vibrates like crazy. I now have to put a stick under the motor to stabilize it while not making the belt too lose. Does anyone have one of these saws and if so did you have the same problem and did you fix it?
Thanks
-- "Courage is being scared to death -- but saddling up anyway."
42 replies so far
View Howie's profile
Howie
2656 posts in 3159 days
#1 posted 01-01-2012 02:34 AM
Don: I used to live in Vegas.
You have an accident waiting to happen I think. My solution is there is a large lake close by with lots of boats…..
Sounds like a bent shaft.
-- Life is good.
View madts's profile
madts
1884 posts in 2575 days
#2 posted 01-01-2012 02:39 AM
I did and put a new belt on it. Since the pulleys are so small in dia. they get a set that can cause bad vibration. I replaced mine with “power twist link belts” from Rockler. Runs very smooth now. My saw is a 12” contractor saw about 30 years old. I hope this works for you.
-- Thor and Odin are still the greatest of Gods.
doninvegas
#3 posted 01-01-2012 03:06 AM
Madts,
I have changed belts including a power link It didn’t work.
Howie,
Lake Mead is close but I can’t afford a new saw, otherwise this one would bo on CL or be sold as a boat anchor.
View sandhill's profile
sandhill
2128 posts in 4159 days
#4 posted 01-01-2012 03:35 AM
Check the amps that it is drawing Don if its high without a load its bearings. Sometimes the bearings will cause vibration when they dry out, sounds like your starting to experience bearing failure in the early stages. You can take it to a repair center which is cheaper than a new saw, do it soon before it spins the shaft.
View Grandpa's profile
Grandpa
3261 posts in 2911 days
#5 posted 01-01-2012 04:18 AM
I have a friend that owns this saw and it vibrated badly. We checked it out and it was the belt sheave. I don’t remember which one (motor or arbor) but I think he changed both of them and got a new belt while he was there. Just the regular V-belt. It is smooth today. I would look there then I would check for a bent shaft in the motor.
doninvegas
#6 posted 01-01-2012 11:43 PM
All good suggestions, thanks. The bearings seem fine and I can’t detect any bend in the shaft, although I don’t have a dial indicator to be sure. The strange this is that with just a little bit of support under the motor it runs smooth and quiet but when the motor hangs free it shakes. I’m thinking of removing the spring loaded mounting pins and just bolt the motor the mounting support to see if that clams thid thing down.
View knotscott's profile
knotscott
8174 posts in 3611 days
#7 posted 01-02-2012 01:12 AM
To isolate the problem, try taking the belt off and run just the motor. If it still vibrates you know where the issue is.
doninvegas
#8 posted 01-02-2012 01:26 AM
Thanks, knotscott I’ll try that.
View klw's profile
klw
17 posts in 2596 days
#9 posted 01-02-2012 04:58 AM
Pulleys themselves may be out of balance. Perhaps the tension spring is a bit loose or soft…
Shaft can be checked with a simple jig to hold a small wire or nail up to the shaft as it spins – will give you some idea. The amount isn’t really important – just that fact that it may be bent.
-- I don't remember being absent minded...
View IrreverentJack's profile
IrreverentJack
727 posts in 3079 days
#10 posted 01-03-2012 08:52 AM
Your saw might have the 2 piece arbor pulley. My 36-979 does. I’ve read complaints about it loosening and causing vibration. -Jack
doninvegas
#11 posted 01-06-2012 11:18 PM
Here’s what I did today. Took the belt off and fired it up. The motor ran smooth. Put the belt back on and removed the blade and there was a slight vibration but it is livable. Now I’m saying to myself, What the hey. I put the blade back on and the motor jumps all over the place. OK, I got a bent blade. Nope the blade is flat and true. I use the Freud blades and this is about the 10th one I have had on this saw in the past 5 years and I have always had this problem. So, I tried another blade of a different make, same problem. I put a full kerf blade on it that I check for flatness and the motor still jumps. The saw is the Delta 36-979 with the single pully on the arbo rand the nut is tight. I’m really at a lose here.
View ChuckV's profile
ChuckV
3183 posts in 3763 days
#12 posted 01-06-2012 11:25 PM
Since there is a slight vibration with the belt and no blade, perhaps the arbor is bent. Then when you install the blade, the small arbor wobble is amplified.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
doninvegas
#13 posted 01-06-2012 11:54 PM
That very well could be. If that is the case then I’ll just have to keep proping up the motor. Bummer.
ChuckV
#14 posted 01-07-2012 12:51 AM
doninvegas – Put the belt back on and removed the blade and there was a slight vibration
cr1 – you got no vibration until you add the last element – the blade – and that’s the only time it vibrates
I do not follow.
doninvegas
#15 posted 01-07-2012 01:22 AM
It’s very possible that all 13 blades I have either used or just tried are a little off. That and arbor being slightly out of round would cause the motor to jump around. I have used Freud, Delta, DeWalt and Forest over the years but I have always had this problem. When I say slight vibration with no blade I mean you feel the vib. but you can barely see it. I can live with that. After all it is a contrator saw I don’t expect perfection. I agree with cr1, what else could it be but the blade? I’m thinking of removing the spring loaded pins that hold the motor on and bolting the motor to trunoin. If that doesn’t work then I’ll just keep supporting the motor with a stick.
showing 1 through 15 of 42 replies
