Leak in tool shed. Now my lie nielsen..
« back to Hand Tools forum
Forum topic by JamieH posted 01-01-2012 12:30 AM 1305 views 0 times favorited 11 replies Add to Favorites Watch
View JamieH's profile
52 posts in 2730 days
01-01-2012 12:30 AM
low angle block plane has pretty good rust on the sole. I dont want to damage it any further. Any suggestions? Is my only answer sandpaper and a flat surface? ughhhhh. I feel sick.
11 replies so far
117029 posts in 3509 days
#1 posted 01-01-2012 12:34 AM
View DocBailey's profile
584 posts in 2291 days
#2 posted 01-01-2012 03:43 AM
Here is my advice: Use a sharp razor blade to “shave” the rust from the sole. For any remaining rust or oxidation, use a grey (not maroon) scotch brite pad lubed with WD-40 to scrub the affected areas. If you are concerned with affecting flatness, then use 320-400 grit Silicon carbide wet-or-dry lubed as above on a flat surface. In my experience – all of the well-known rust removers (Evaporust, naval jelly, citric acid) will impart an ugly cast to your plane.
10084 posts in 3579 days
#3 posted 01-01-2012 03:50 AM
I use a brass “suede brush” (get one in the shoe care section or at
a leather repair shop) to get top rust off. After than I use a
“Wunderbar” (available from Garrett Wade).
Actually, don’t freak out. If I freaked out every time a tool got some
rust on it I would have quit this stuff years ago to escape the stress.
View ChuckV's profile
3102 posts in 3459 days
#4 posted 01-01-2012 03:51 AM
You might try giving LN a call. I bet that they will give you some good ideas about the best approach.
Good luck.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
View David Grimes's profile
David Grimes
2078 posts in 2571 days
#5 posted 01-01-2012 04:30 AM
It is an omen. God is telling you to put away your foolish primitive tools. Coveteth not thy neighbors planes. ;=)
Seriously, Evaporust.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
View NormG's profile
5900 posts in 2935 days
#6 posted 01-01-2012 04:51 AM
Ouch, I saw someone use white rubbing compound on a piece of glass, just move it around on it. They removed most of the rust first with a plastic razor blade
-- Norman - I never never make a mistake, I just change the design.
View Dallas's profile
3599 posts in 2419 days
#7 posted 01-01-2012 05:18 AM
It’s trashed, you might as well send it to me so I can give it the disposal rites it deserves.
Sorry to hear about the accident. I hope you get it cleaned up nicely and put it back to work.
View mikema's profile
180 posts in 2517 days
#8 posted 01-01-2012 05:30 AM
Evaporust is great. I used it to restore a plane that was solid rust into something shiny and useable.
-- Mike ---- Visit my woodworking blog:
View ksSlim's profile
1272 posts in 2821 days
#9 posted 01-01-2012 06:27 AM
Razor blade and light grey (fine) Scotch bright. Abralon also makes 4000 pads that give a nice polish.
-- Sawdust and shavings are therapeutic
View drfunk's profile
223 posts in 2608 days
#10 posted 01-01-2012 07:54 AM
I wouldn’t use chemical dips unless I absolutely had to. I would first try mineral spirits and a light scotch brite or steel wool. If that isn’t enough, maybe a brass brush or even a wire wheel on a Dremel. A call to Lie Nielsen will give you a definitive strategy – fo’ sho’.
View NateX's profile
98 posts in 2928 days
#11 posted 01-02-2012 08:02 AM
Have you tried just oil and a tooth brush? Surface rust can come off really easily. I have rubbed off rust with just a paper towel and mineral oil.
If you want to see how Shannon Rogers gets rid of rust on his LN block plane, watch this video.
FWIW, I would use a chemical as a last resort. Just clean the plane and oil it up. You will be fine.
I just use 3 in 1 oil because paying $20 for a bottle of camellia oil sounds ludicrous.
