Impossible doweling?
Forum topic by Kindlingmaker posted 12-31-2011 02:27 AM 1386 views 0 times favorited 10 replies Add to Favorites Watch
View Kindlingmaker's profile
Kindlingmaker
2656 posts in 3397 days
12-31-2011 02:27 AM
Had anyone been successful glueing tight fitting dowels in deep non through holes without the dowels being kerfed for air/glue escape?
10 replies so far
View Grandpa's profile
Grandpa
3259 posts in 2546 days
#1 posted 12-31-2011 02:30 AM
Not much luck with that. Take a utility knife and cut a groove in the side or get some pliers and make flutes up the side.
View FirehouseWoodworking's profile
703 posts in 3144 days
#2 posted 12-31-2011 02:37 AM
Drill a hole of the appropriate size in a pice of hardwood, about an inch from the edge. Predrill and drive a screw in from the edge so that the screw pointsticks into the dowel hole.
Now drive the dowel through the hole and the screw point will score the dowel. If you want more than one relief scouring, drive the dowel through again, turning the dowel, for as many grooves as you want.
Works great if you cut your own dowels to length. Don’t forget to chamfer the ends of the dowels on a sander or pencil sharpener. Makes it easier to insert them and leaves a little space for the glue when you bottom out the dowel.
Cheers!
-- Dave; Lansing, Kansas
404 - Not Found
2544 posts in 2840 days
#3 posted 12-31-2011 02:45 AM
Best and quickest way to put a kerf in a dowel I’ve found is to stand it up and push it into bandsaw blade. Tilt it back so bottom grooves first, then bring it to vertical. Then chamfer it (stick it in chuck of drill and use sandpaper). Mind your fingers on bandsaw. You will blow out sides or force glue thru the grain if you don’t incorporate glue relief in the dowel. Be sparing with the glue, use a Q tip (cotton bud) as a glue spreader in the hole.
View Clint Searl's profile
Clint Searl
1533 posts in 2232 days
#4 posted 12-31-2011 03:13 AM
Are dowels good for anything that can’t be done better and easier some other way?
9760 posts in 3518 days
#5 posted 12-31-2011 03:21 AM
Actually dowels are the preferred joint for much commercial
casework. With the right equipment, doweling is fast, strong
and the joints are dead on. No other joinery method controls
the relationship between joined parts so precisely.
If you aren’t making a hydraulic pressure issue at the bottom
of a stopped hole, you can glue a round stick into a round
hole without kerfing the stick. With a through hole, using
a smooth rod should not present a problem.
16272 posts in 4089 days
#6 posted 12-31-2011 03:28 AM
Ditto what Loren said, Clint. Doweled joints have been tested to be generally as strong as mortise and tenon joints, and a doweling jig makes it fast and easy work.
View klw's profile
klw
17 posts in 2231 days
#7 posted 12-31-2011 07:34 AM
Plus leave just a ‘tad’ of room at the ends so the dowel doesn’t bottom out.
-- I don't remember being absent minded...
View tenontim's profile
tenontim
2131 posts in 3615 days
#8 posted 12-31-2011 03:33 PM
I use just a small amount of glue, that will be spread down the bore when you drive the dowel in, not enough to really puddle at the bottom. You have to drive the dowels in fast before the glue has time to set up enough to grab the dowel. If the dowels fit tight, you really don’t need much glue.
Kindlingmaker
#9 posted 12-31-2011 05:01 PM
Thanks everyone! A lot of great advise! I am using dowels as part of the “art” of the project and not the joining of pieces together.
View sedcokid's profile
sedcokid
2729 posts in 3469 days
#10 posted 01-16-2012 03:52 AM
These are some good suggestions!!
-- Chuck Emery, Michigan,
