| Forum topic by agallant | posted 507 days ago | 876 views | 0 times favorited | 12 replies | ![]() |
507 days ago |
I just bought a 3HP unisaw. I have a thin kerf and a full kerf WWII. Which one should I use? Does it matter? |
12 replies so far
#1 posted 507 days ago |
From what I have read, thin kerf saw blades are more useful for saws lacking in horse (1.5 or under) and that on higher power saws they can take a bit of a hit on stability. David -- There is little that is simple when it comes to making a simple box. |
#2 posted 507 days ago |
Full, unless you want to save wood loss. Thin kerf requires less |
#3 posted 507 days ago |
I prefer to stick with full kerf blades, since full kerf are generally the same across manufacturers (.126 or just a thou over 1/8”). This keeps all my zero-clearance fences/sleds as zero-clearance. Everyone’s thin kerf is just a bit different. -- Optimists are usually disappointed. Pessimists are either right or pleasantly surprised. I tend to be a disappointed pessimist. |
#4 posted 507 days ago |
I have the same saw, and switch between blades alot, using thin kerf and full kerf. As was said, saving material is a primary use for thin kerf. Not a worry with your saw. -- Randy "You are judged as much by the questions you ask as the answers you give..." |
#5 posted 507 days ago |
Full kerf. Less blade wobble with a full kerf and if you you have the horsepower then go with the full. |
#6 posted 507 days ago |
Apparently nobody uses a splitter or riving knife. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#7 posted 507 days ago |
With that much power I’d use full kerf unless I had lots of expensive wood to cut. Thin kerf is easier for a smaller saw to spin. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#8 posted 507 days ago |
I use a thin kerf blade with a stabilizer. On very rare occasions, the stabilizer gets in the way and I remove it. I have a 2 hp motor on my ts. Even if I had a more powerful saw, I would probably stick with a thin kerf and a stabilizer. Why waste the wood and create more sawdust? In my opinion, the stabilizer compensates for almost all of the extra wobble in a thin kerf blade. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
#9 posted 506 days ago |
I have both kerf sizes and for some reason just seem to use my full kerf more often. Mine is one a 1.5hp hybrid saw and I have not had any trouble ripping 5/4 hardwood. |
#10 posted 506 days ago |
I don’t think it matters most of the time. My standard kerf blad is nicer (WWII) so I use that. My saw came with 2 riving knifes so I can use both standard and thin. -- Although the voices aren't real they have some pretty good ideas. |
#11 posted 506 days ago |
I do the same as Rich. I have a 3 HP saw and I use the thin kerf blade with the stabilizer. I like the way it cuts (I actually think it cuts faster) and like Rich said I probably would stick with it no matter what the HP. -- Wayne - Plymouth MN |
#12 posted 506 days ago |
OK I’ll mention it. Splitters and riving knives are a waste of time and effort serve no practical purpose and are always in the way. As to whether you should use a thin blade: A down side is they deform easily. One ding and it may be curtains for your blade. -- When the moderator chooses sides, his site sucks. |
| Forum | Topics |
Woodworking Skill Share
8790 |
Woodturning
220 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1529 |
3547 |
15767 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6155 |
