Calibrating a moisture meter?
Forum topic by Mark Shymanski posted 507 days ago 720 views 0 times favorited 2 replies Add to Favorites Watch
View Mark Shymanski's profile
Mark Shymanski
3966 posts in 1880 days
507 days ago
Topic tags/keywords: moisture meter calibration
Having received a moisture meter for Christmas I was wondering if there is a way to validate the readings it is giving?
My first thought was to take a piece of wood measure the moisture content with the meter then weigh it (I have a pretty good balance here so I think I can get a good measure of the mass) then microwave the sample until it is ‘drier’ measure the mass again and then re measure with the moisture meter. I am hopeful that the change in mass is proportional to the change in moisture reading. This is assuming that the microwaving will dry out the wood. I should be able to calculate the moisture content from the change in mass, shouldn’t I? I’d sure appreciate any assistance on this. Thanks in advance.
Mark
-- "Checking for square? what madness is this! The cabinet is square because I will it to be so!" Jeremy Greiner LJ Topic#20953 2011 Feb 2
2 replies so far
34370 posts in 2568 days
#1 posted 507 days ago
Here is a manual on calibrating for particle board but it did have a fornula for use on page 7
http://www.9wood.com/files/rd_reports/moisture_meter_calibration-vesta.pdf
So you would test the wood you have then oven dry it and then use the formula to calculate the original MC. Then check it with you test.
I have a Lignomat DX/C meter and the MFG states that it does an internal calibration when being used. So I can’t be of any help there.
What meter did you get.
I did a search on Google and there are a lot of references and a link to a MFG web site that has a way to calibrate theres.
View Rick L's profile
Rick L
511 posts in 1929 days
#2 posted 507 days ago
A regular oven is better and a decent scale will work. You can buy a good inexpensive digital scale from Harbor Freight or similar venue. That is a common technique before moisture meters. Lignomat and Delmhorst sell calibration test blocks for their meters, which is what we use. Do not believe they can be used on just any brand meter. Basically a resistor calibrated to give a specific reading. The weighing method works but is slow. Buy a brand that sells the test block. On the other hand the meter is more to make sure your wood is of the same reading for balanced construction.
-- Few folks really know how to maximize the potential of their tools!
