How hot should it be
Forum topic by GuyK posted 509 days ago 804 views 0 times favorited 7 replies Add to Favorites Watch
View GuyK's profile
GuyK
346 posts in 2249 days
509 days ago
Topic tags/keywords: question milling
We at the farm are milling about 50 logs into lumber for our own use. We are going to make our own kiln using a portion of a heated greenhouse. My question is how hot should the temp be in the greenhouse to effectively dry the wood in a reasonable amount of time?
-- Guy Kroll www.thelandsathillsidefarms.org
7 replies so far
View daltxguy's profile
daltxguy
1323 posts in 2084 days
#1 posted 509 days ago
Not too hot. I just read recently somewhere ( though I can’t recall where) that around 100F is sufficient. The key to drying wood in a kiln is moisture removal, therefore air circulation. Also, you don’t want to dry too fast. Too fast and the wood will check or honeycomb. Not enough air circulation and the wood may mold. So, it’s a balance between heat which helps to remove moisture and air circulation which carries it away.
I think much depends on what kind of wood you are drying too. It’s an art. Ring porous woods will dry faster through the ends, therefore prone to checking and honeycombing through too fast drying so these probably need to be sealed on the ends.
Having said that, don’t take my word for it – I’ve never dried wood in a kiln – only air drying and there I keep the wood in the shade but well ventilated. I dry mainly pines and NZ beech. The NZ beech needs very slow drying. The pines are mainly susceptible to growing molds in a high moisture environment but dry relatively quickly even at room temperature.
-- If you can't joint it, bead it!
View Nomad62's profile
Nomad62
567 posts in 1128 days
#2 posted 509 days ago
around 100 f is pretty typical, all the things daltxguy are right on. With decent ventilation and temp you can dry it well in 30 days or so.
View GuyK's profile
GuyK
#3 posted 509 days ago
Thanks Daltxguy and Nomad for your input. We are new to trying this so any information is a big help. 100F should not be hard to reach in the greenhouse. We are using a wood burning outside heating unit that provides lots of btu’s. Air circulation will be buy about 4 or 5 fans. I will let you know how it turns out.
View WDHLT15's profile
WDHLT15
686 posts in 646 days
#4 posted 508 days ago
Drying wood in a kiln is a combination of both humidity and temperature, not just temperature. Google “Drying Hardwood Lumber”. That is a good resource and you will learn a lot about drying wood.
-- Wood-Mizer LT15
View HalDougherty's profile
HalDougherty
1820 posts in 1407 days
#5 posted 508 days ago
Here is a link to the best site on the Internet about solar kilns, plans to build one, how to use one, and construction photos.
http://woodscience.vt.edu/about/extension/vtsolar_kiln/
You can also google “Virginia tech solar kiln” and find more information.
-- Hal, Tennessee http://www.first285.com
View Scsmith42's profile
Scsmith42
125 posts in 847 days
#6 posted 508 days ago
Guy, I’m a kiln operator. I second WDH and Hal’s advice re Gene Wengert’s “Drying Hardwood Lumber” manual as well as the Virginia Tech solor kiln manual.
Drying rates, temps, and RH% varies depending upon the species, thickness and initial moisture content of the lumber. 100F as a starting temp is acceptable for certain fast drying species, but is too hot for slow drying species such as oak, especially thick oak.
What species and thickness are you planning to dry, and will you be going straight from the sawmill into the kiln or air drying first?
-- Scott, North Carolina, www.quartersawnoak.com
View GuyK's profile
GuyK
#7 posted 507 days ago
Thanks to everyone for all the good information. Scott I will be drying, Hemlock, Cherry, Maple, Oak, Ash, Walnut and Pine along with some Spruce. Thickness will be mostly 1 1/4 inch with some thicker stock, 2 to 3 inches. Yes it will be going straiight from the sawmill to the klin ( just a couple of days air drying ).
Scott if 100 F is to hot for slow drying species, do you have a temp you would recommend that would be a good average for all wood.
