20x20 garage dust collection suggestions
Forum topic by Matt Przybylski posted 537 days ago 1297 views 0 times favorited 4 replies Add to Favorites Watch
View Matt Przybylski's profile
Matt Przybylski
303 posts in 575 days
537 days ago
Topic tags/keywords: dust collection garage
Hello fellow LJs,
Here is my situation: I’ve got a 20×20 two car garage that doubles as a shop. Most everything is mobile but now I’ve pretty much run out of room and have no floor space when the cars are in to add anything else. My birthday is coming up and the wife asked what I wanted. I’m deciding between a dust collector or an hvlp spray system but as of right now the DC would be more practical because I find myself using my compressor with a blow gun about once a week to clean my tools. I also have a shop vac but it’s proving to not be enough as I always seem to get a bunch of dust everywhere regardless.
The question becomes this: what are my options as far as wall hung units (recommendations would be great) and should I go with something like the new rockler hose that goes from 3 or 4’ to about 12’-15’ since space is an issue? I’m not opposed to moving the hose around from tool to tool as all I really have is a TS and router table (on the right wing of the TS), a benchtop drill press, and my parents are getting me a benchtop planer for my birthday. I’ll only really be using one tool at a time and the budget is probably around $300 for EVERYTHING (dc unit, hose, connectors, etc).
I’m in suburban Chicago and I have an electric heater that heats up the garage very nicely (thought I’d throw this info in here in case it makes any difference).
Thanks for any help anyone can offer.
Matt
-- Matt, Illinois, http://www.reintroducing.com
View Grandpa's profile
Grandpa
2399 posts in 872 days
#1 posted 537 days ago
I have seen Harbor Freight mounted on the wall and read favorable reviews. Most of the people with them think they are great. They are in the $150 range with a coupon. The Rockler wall mounted unit is about $225 I think. The HF unit with a separator and better filters should do a great job. Another thing to think about is filtering the air in the work space while you are working. A dust collector is just a big vacuum cleaner and the fine dust remains in the air to breath. The fine dust is removed with filter system and filters that work in the 1 micron and less range. These just filter the air. The “store bought” units are in the $300 and up range. You can build one of these and buy the .5 micron filters from various suppliers that sell the machines.
5028 posts in 1845 days
#2 posted 537 days ago
Buy a used dust collector. You may be able to find one with pipe
and blast gates and stuff.
Dust collectors have soft resale value so there are plenty of
bargains to be sound.
I went to a central system with ducting recently (cyclone) and
it’s just so nice to have the dust collector out of the way. The
cyclone is made from a “Wood magazine” plan.
Matt Przybylski
#3 posted 536 days ago
@Grandpa: Which unit from HF are you talking about in particular? They seem quite large and floor models. Also, I’ve seen (but lost links to) plans for air filtration systems online. Do you have any links in particular to some good plans?
@Loren: I’ve been looking on CL but no luck recently in my area. They are all very large units that I don’t have room for. As for the cyclone in Wood, apparently that material cost is $385 alone + $64 for the remote switch, not to mention I don’t really trust myself building something like that and the fact that it takes up a lot of valuable floor space on top of having to run duct work to areas of my garage that I’m not sure will always be used the same. :\
This is turning out to be a bigger decision than I thought. I think more research is in my future before I can make the proper decision on this.
View Jimbo4's profile
Jimbo4
728 posts in 960 days
#4 posted 536 days ago
I’ve gotten a bunch of side advice about a HF 1hp DC. It look like and, takes up about the same space as the wall mounted Rockler, and I think more cfm (?), plus it’s about $150 on sale and less with the 25% off coupon you can get on-line from HF. I’m going to get one, then hook (try) it to my Onieda Dust Devil for chip removal prior to entering the unit. My 1/3 garage usage, of a 3 car, is down to an almost bare minimum, even with everything on wheels ! Got to try something, as my space looks like a dust bin.
-- * Reintarnation * : Coming back to life as a hillbilly.
