Repairing broken sander belts
Forum topic by RusticElements posted 1863 days ago 7225 views 0 times favorited 16 replies Add to Favorites Watch
View RusticElements's profile
RusticElements
167 posts in 1923 days
1863 days ago
Topic tags/keywords: question sander
Is it possible?
I went through several sander belts on a recent stair refinishing job. Not that the belts wore out, they broke. Yes I had them on the right way. The belt sander belongs to my neighbor and I think the belts may be quite old.
What I’m wondering is, is there a way to repair them? Can I remove the existing spicing tape and put on new tape of some kind? It seems a shame to throw out perfectly good belts. Hey! I’m Scottish! What can I say?!?
-- Michael R. Harvey - Brewster, NY - RusticElementArt.com - SpaceAware.org - AnConn.com
16 replies so far
3808 posts in 2219 days
#1 posted 1863 days ago
They are pretty inexpensive. I think I pay about 80 cents each for the 3×21” belts.
That being said, I suppose you could get a roll of seaming tape for carpets and give it a try.
Some use linen with crazy glue.
Remember all these remedies cost money too.
bob
View GaryK's profile
GaryK
10263 posts in 2185 days
#2 posted 1863 days ago
Epoxy might work. I would just buy another.
View lew's profile
lew
9035 posts in 1952 days
#3 posted 1863 days ago
Mike,
Your assumption about old belts is probably correct. My shop is in the basement and it can be a little humid. I experienced several belt failures on belts that were brand new but had been stored in the shop for many months. Newly purchased belts worked fine.
I agree with Bob and Gary- replace rather than repair
Lew
-- Lew- Time traveler. Purveyor of the world's finest custom rolling pins!
17950 posts in 2048 days
#4 posted 1863 days ago
Mike, never had one break luckily. I cut the old ones into strips for sanding blocks & on the lathe. So they are not really wasted.
RusticElements
#5 posted 1863 days ago
A Jewish friend of mind says he knows what happened to the lost tribe of Israel… They ended up in Scotland.
My Grandmother was well known for spending $1 on gas in order to save $0.10 at at sale…..
I guess I’m a little too much like my grandmother….
Ok, I give, I’ll buy new ones.
34396 posts in 2598 days
#6 posted 1863 days ago
Well I’m like Rustic Elements.
I’ve got about 50 belts and they are each breaking within 1 minute of turning them on. 1” wide belts and 4” wide belts.
I’d like a way to salvage them.
View Mark Shymanski's profile
Mark Shymanski
3958 posts in 1910 days
#7 posted 1863 days ago
I think any repaior that you’d do to the belt would shorten it too much to be able to mount it on the BS. I think Grumpy has the best idea, use them somewhere else to get the value out of them.
-- "Checking for square? what madness is this! The cabinet is square because I will it to be so!" Jeremy Greiner LJ Topic#20953 2011 Feb 2
View Mario's profile
Mario
902 posts in 2248 days
#8 posted 1863 days ago
I agree, buy some new ones, Keep the old ones and glue them to blocks of wood to sand edges.
-- Hope Never fails
RusticElements
#9 posted 1863 days ago
I just looked on Lee Valley. These things are $3.15 each for 4” x 24”. Of course, knowing my neighbor, the ones that broke are probably the $0.99 variety. Theoretically, the better ones should last longer.
View beemerbob's profile
beemerbob
8 posts in 1992 days
#10 posted 1858 days ago
Had the same problem. Turning the belts in sanding blocks, large surface sanding, etc. I was told by the Klingspore folks that most belts should be used within one year of purchase
bob.
-- Bob from Northwest Florida
View bryano's profile
bryano
546 posts in 2130 days
#11 posted 1858 days ago
I get mine from Big Lots for about a 1$. I wear them out without breakage. the only proglem is not much grit selection there.
-- bryano
View 221mcharg's profile
221mcharg
1 post in 689 days
#12 posted 689 days ago
I had 35 belts 4”X36” where the seam failed. I tried numerous methods to find a fix.
Here is what I finally found that works.
Get a roll of “iron-on” carpet tape from home depot or lowes. A lifetime supply is about $7.00.
cut strips from the carpet tape to fit the seam on the back of the sanding belt.
Remove the existing adhesive strip from the back of the sanding belt.
Rough up the surface of the back of the belt with sandpaper.
line up the ends of the sandpaper belt and apply the carpet tape with an iron. The iron must be turned to HOT.
The repaired belt will produce a little “bump” as the carpet tape adds some thickness but it is better than throwing away good belts.
View MrRon's profile
MrRon
1635 posts in 1440 days
#13 posted 688 days ago
I had the same problem and tried many different tapes, but none would hold. I finally contacted a belt manufacturer (Carborundrum, I think) and asked them what tape is used. Their reply was; the tape was prioritary. I guess you will have to buy a good belt. They last longer than cheap belts, HF for example.
View gfadvm's profile
gfadvm
6907 posts in 887 days
#14 posted 688 days ago
When I started buying Norton 3x belts, this problem went away! They are spendy but worth every penny.
View Tim Kindrick's profile
Tim Kindrick
369 posts in 751 days
#15 posted 687 days ago
I never throw away belts that break. Instead I attach them to scrap pieces of wood with different shapes for hand sanding and shaping. It works great and they last a long time like this!!!!!
-- I have metal in my neck but wood in my blood!!
