How do I fix this
« back to Hand Tools forum
Forum topic by dozuki posted 12-29-2011 05:33 AM 1052 views 0 times favorited 7 replies Add to Favorites Watch
View dozuki's profile
dozuki
103 posts in 2963 days
12-29-2011 05:33 AM
I am trying to refurbish this drill for a friend of mine as a late christmas present and am wondering how I can fix the “collar” on this. I hope you can see the crack where the handle joins the mechanism. Thanks for your help.
-- Couldn't think of anything clever. I LIKE WOOD
7 replies so far
dozuki
#1 posted 12-29-2011 05:35 AM
Sorry i missed a step in posting the photo so here it is. Thanks again
View Grandpa's profile
Grandpa
3259 posts in 2637 days
#2 posted 12-29-2011 06:12 AM
That is a tough one. I think I would try to remove the handle. It looks like it has a threaded rod or bolt that holds it on. If you can get to the this end of the handle I think I would loot at a small piece of very thin brass tubing or maybe copper tubing that would fit this. The copper or brass can be heated in a conventional baking oven and it will slip over this and tighten provided it is small enough it doesn’t fall off in the beginning. It needs to be a size that will almost go on in the beginning. Then you could sand this down and polish it a bit to dress it up. This is mostly cosmetic anyway. I don’t think you will ever replace it unless you can replace the entire handle. I made some Christmas ornaments and used brass ferrules like this but I was turning the end of the ornament to fit the ferrule. All I can think of right now.
View DIYaholic's profile
DIYaholic
19596 posts in 2637 days
#3 posted 12-29-2011 06:14 AM
I’m thinking “duct tape” is the wrong answer!
The crack could be welded and then ground & filed smooth. What is the metal? Aluminium, cast metal? I would think that a good welder should be able to handle it.
View fussy's profile
fussy
980 posts in 3012 days
#4 posted 12-29-2011 09:22 AM
It’s an old drill, right? That’s a cosmetic problem, and adds interest. You would do more damage than good trying to fix it. Leave it be. Happy New Year.
Steve
dozuki
#5 posted 12-29-2011 06:53 PM
Thanks for your replies. I’m thinking that I might just clean it up and leave it and just call it “character”. Or maybe I could find another old junker with a good handle to replace the cracked one.
Thanks again.
View Builder_Bob's profile
Builder_Bob
161 posts in 3021 days
#6 posted 12-29-2011 07:28 PM
Wrap it with wire.
-- "The unexpected, when it happens, generally happens when you least expect it."
View Dallas's profile
Dallas
3599 posts in 2449 days
#7 posted 12-29-2011 07:36 PM
That looks like nickle plated brass. I would try silver solder or my new toy, Alumiweld. If those don’t work, you might try brazing some bronze rod into it, then coat with a layer of Alumiweld or Silver Solder.
