Remote dust collector starter
Forum topic by Bobsboxes posted 12-29-2011 02:37 AM 1440 views 0 times favorited 6 replies Add to Favorites Watch
View Bobsboxes's profile
1344 posts in 2597 days
12-29-2011 02:37 AM
Topic tags/keywords: dust collector remote start gate switches
What does everyone use to start d/c? I was looking at the long range system, that has wires to all gates, when you open gate it starts collector. I have remote on my grizzly system, but I have a hard time remembering to bring button along.
-- Bob in Montana. Kindness is the Language the blind can see and deaf can hear. - Mark Twain
View Eric_S's profile
1565 posts in 3128 days
#1 posted 12-29-2011 04:53 AM
I have a delta 50-720 that I switch between machines using rocklers 4” quick release hose. I have it centered between my machines and just switch the power outlet when I switch machines. I use this, which turns on the collector a couple of seconds after the tool so it doesn’t put too much of a strain on the circuit and it stays on for about 7 seconds after the tool is turned off to pull the dust out of the tube. I am VERY happy with it.
This may not be the best solution though if you aren’t always switching plugs. It sounds like you have everything hosed up permanently. I’ve seen on here a while back a post about a special modification to the circuit itself that turns on the dust collector circuit when anything on a tool circuit turns on. Can’t remember the post though.
-- - Eric Noblesville, IN
View JJohnston's profile
1622 posts in 3224 days
#2 posted 12-29-2011 05:02 AM
I bought several remote transmitters, and installed one sort-of-permanently (double side taped down) at each machine.
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View gfadvm's profile
14940 posts in 2623 days
#3 posted 12-29-2011 05:17 AM
Clip that remote starter to your shirt but don’t let your kids see you. My daughter thought I had gotten one of those “Help I’ve Fallen And I Can’t Get Up thingys”. I’m still hearing about that!
View zindel's profile
257 posts in 2583 days
#4 posted 12-29-2011 05:22 AM
I have been thinking about the exact same thing. there is a craftsman that is just like the one from rockler for less..found here but i have also found these but i don’t know how well these work either. just a few options
-- If you can't fix it with a hammer, You've got an electrical problem.
View Gene Howe's profile
Gene Howe
10253 posts in 3361 days
#5 posted 12-29-2011 05:26 AM
I super glued a rare earth magnet to remote switches and set them on the planer, Jointer and TS.
#6 posted 12-29-2011 09:23 PM
Thanks for the imput, not sure what I will do yet. But appreciate the imput. Got a real charge out of gfadmv’s response, I could hang it on a string around my neck, but would probably get hung up on a machine and get sucked in, or get accused of wearing life alert like gfadmv. Reminds of a time when I helping a friend build a bumper and he was at my drill press drilling the mounting holes and his t-shirt got caught in a 4” piece of metal that was hung up on bit and sucked his shirt off him in a second. He is a big guy, like pulling a sail off a sailboat….but lucky he didn’ get hurt. thanks again Bob
