Forum topic by 308Gap | posted 12-29-2011 12:38 AM | 1604 views | 0 times favorited | 15 replies | ![]() |
I made a bunch of cutting boards for family and friends for xmas. These two boards didn’t measure up so I kept them. Heres my question. How would you fix these so they are usable ? , epoxy fill, or drill and plug with similar wood dowel, or paint it and make a dart board. Both boards are maple and walnut with salad bowl finish. This first one has bug holes only in the 3/4’’ ripped walnut. The second board has one knot hole on the back. More pics here if it helps. http://s199.photobucket.com/albums/aa207/johnpebley/stuff/ -- Thank You Veterans! |
15 replies so far
#1 posted 12-29-2011 12:45 AM |
If you were to drill it and dowel it with the same woods, it would be a functional fix. Doing that or leaving them as is, would be my top 2 choices at this point. Dart board would be pretty far down on my list. Maybe you will get some better suggestions, good luck. |
#2 posted 12-29-2011 12:47 AM |
I vote for drilling and doweling each small block of walnut in the same spot – at least that way you keep a pattern. Or mortising if you have a mortiser… -- Optimists are usually disappointed. Pessimists are either right or pleasantly surprised. I tend to be a disappointed pessimist. |
#3 posted 12-29-2011 12:49 AM |
Drill and plug with dowels. -- He who dies with the most tools... dies with the emptiest wallet. |
#4 posted 12-29-2011 12:53 AM |
Add my vote to the drill and dowel solution. |
#5 posted 12-29-2011 02:10 AM |
I fill voids with sanded sawdust and saturate with superglue. I have several ziplock bags full of different sanded dust just for that purpose -- mike & judy western md. www. pvwoodcrafts.com pvwccf1@verizon.net |
#6 posted 12-29-2011 02:17 AM |
I made a cutting board in a class and there was a void on the back. The instructor had me fill it with a glue and sawdust mixture and while it never looked perfect, it did fill the void and made that side usable. |
#7 posted 12-29-2011 06:37 AM |
Beautiful boards! Looks like you could plane out the top board; No? -- "There are no gains without pains." -Benjamin Franklin |
#8 posted 12-29-2011 06:47 AM |
First one, re-size and re-finish. Second one, does the knot go clear through? If so, then there’s a problem, if not, then the hole will not be exposed to meats and will not gather bacteria. -- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them. |
#9 posted 12-29-2011 06:48 AM |
drill and dowel sounds like the safest way. I also thought of glue and sawdust, but the sald bowl finish wont penetrate the glue. Thanks for the input everyone. -- Thank You Veterans! |
#10 posted 12-29-2011 06:54 AM |
Well, if you want to try glue and sawdust. There is a product called wood cement, you mix this with wood dust and it is usually permeable to finishes and stains. But a method I came up with for filling cracks and blemishs in aromatic cedar is to get clear trim carpenter’s glue, which is white. Fill the hole with it, take a damp rage and wipe it so that the glue is just below the surface then sand. The glue wasn’t on the top, just the dust, so the cracks did not turn black, so “maybe” a finish would penetrate? It’s kind of hard to tell. Personally I use a butcher block finish so it’s a lil different. I’m also experimenting with using wood patch on some that I recently made, to see how it will hold up, but I don’t think it comes in purple heart, though it can be tinted or stained. -- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them. |
#11 posted 12-30-2011 06:21 AM |
I’m in a similar situation. I made a walnut and maple cutting board, and the maple had quite a few little holes from insects. I’m wondering if super glue/sawdust would be safe. The holes are big enough that I am concerned about bacteria. -- Mitch, http://furnitude.blogspot.com Also blog at http://www.craftsy.com/blog/author/mitch-roberson/ |
#12 posted 12-30-2011 04:23 PM |
make a jig to cut the pieces out with a trim router and do a inlay patch with the same material /glit—- glue and s**t mixed together doesnt ever come out right . -- nelson woodcrafters |
#13 posted 12-30-2011 11:35 PM |
Furnitude thats my concern also. I do have an inlay set though…....hmmm. But plugs from the same stock might just fit. -- Thank You Veterans! |
#14 posted 01-02-2012 08:32 AM |
How about random shapes in contrasting colors that are let into the surface to create a different effect? -- "certified sawdust maker" |
#15 posted 01-04-2012 06:52 AM |
I see your angst. A beautiful board like that is worth an effort to save. I think I would cut out the offending defects out as strips and then try to glue the ends back on, flipping of course to keep the alternating pattern. I cant tell where the second defect is in relation to the board, but A similar strategy would work. Please, let us know how it turns out. |
Forum | Topics |
Woodworking Skill Share
12029 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6695 |
28058 |
CNC Woodworking
212 |
Hand Tools
5410 |
Jigs & Fixtures
1419 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4757 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
