Sharpening new chisels
« back to Hand Tools forum
Forum topic by ChuckC posted 12-29-2011 12:10 AM 1822 views 0 times favorited 9 replies Add to Favorites Watch
View ChuckC's profile
ChuckC
828 posts in 2958 days
12-29-2011 12:10 AM
I just ordered an 8 piece Stanley Sweethart chisel set. I’m looking for some recommendations to sharpening them. Since they are new I won’t know how much work the backs will need to get flat. Is there a general rule to what grit to start with? I’ll be using the Worksharp 3000. I know I can start with a low grit and work my way up but I’d rather be more efficient and not grind away more than I have to.
9 replies so far
View Loren's profile
10476 posts in 3671 days
#1 posted 12-29-2011 12:31 AM
I’ll wager the backs of those are pretty close to flat. You start by making
the back flat, but what grit you start at depends on how flat they are
to start with, so assess flatness. If a chisel needs a lot of work start
with something pretty coarse.
Smitty_Cabinetshop
15367 posts in 2641 days
#2 posted 12-29-2011 12:53 AM
I had a very positive experience w/ my SW chisels. Didn’t have much to do on them. Details in my review, also in the forum posts below.
ChuckC
#3 posted 12-29-2011 06:36 AM
I guess I was wondering how to tell how flat each one is? Does starting with 300 grit sounds reasonable?
View jeth's profile
jeth
262 posts in 2861 days
#4 posted 12-29-2011 02:02 PM
I would say 300 or even a little higher is a good start, you want something which will give you a slight scratch pattern on the backs to highlight any areas which are out of flat.
Mark the backs with a sharpie or similar, give them a few strokes on the abrasive and you will see if the lines are being evenly removed. Best to start fairly fine so as not to add a lot of coarse scratches if the backs are in fact close to flat. If the lines are removed in one area but not others, work it a little more , if after a brief lapping you are still not getting an even removal across the whole area then drop down to a coarser grit. If you are taking off all the marks evenly then you are good to start moving through the finer grits and working up to a polish.
With a bit of practice you won’t even need the marker to do this, you can see the scratch patterns, changing the direction of movemement between grits allows you to see where each grit is taking off material, from the change in the fine scratching, or just the “tone” of the metal, as each grit will leave the surface a slightly different tone of ‘grey’.
View Manitario's profile
Manitario
2630 posts in 2906 days
#5 posted 12-29-2011 02:07 PM
I don’t think it matters what grit you start at for lapping the backs; I generally start at 220 and if that isn’t going quick enough I change to 120 grit. I only lap the last 1/2” of the blade, and switch to a finer grit once I can see a uniform scratch pattern from my lapping efforts.
View NJWiliam's profile
NJWiliam
32 posts in 2590 days
#6 posted 12-29-2011 09:59 PM
I would err on the side of coarser for initial flattening. Put the time in to flatten it from the start and you won’t have to flatten again for a long time.
Smitty_Cabinetshop
#7 posted 12-29-2011 10:52 PM
Only unflat I ran across was an upturn at the tip of a couple tools. Scratch pattern easy to see because of the laquer coating on the chisels…
ChuckC
#8 posted 12-30-2011 07:09 PM
Thank you for the advice. They came last night and look pretty good. I noticed that at least one of them has a couple of small nicks on the edge. That one may need a lower grit.
I read somewhere that you are supposed to remove the lacquer before you sharpen? It seems to me that you would want to keep it on for protection with the exception of what gets removed when you sharpen.
View racerglen's profile
racerglen
3112 posts in 2803 days
#9 posted 12-30-2011 08:38 PM
Leave the Laquer and you’ll gum up your sharpening system.
-- Glen, B.C. Canada
