12 in bandsaw concerns
Forum topic by alfonse posted 12-28-2011 10:47 PM 858 views 0 times favorited 4 replies Add to Favorites Watch
View alfonse's profile
alfonse
6 posts in 2577 days
12-28-2011 10:47 PM
Topic tags/keywords: question
i bought a used crafstman 12 in band saw i replaced tires drive belt and drive pully still have a little vibbration in it it looks like upper drive wheel wobbles a little is this normal vibration , or are they supposed to run smooth. the bearings all fell ok but you can only test them without presure on them .so my have a bad one under load ? saw modle 113.24350
View TechRedneck's profile
TechRedneck
770 posts in 3093 days
#1 posted 12-30-2011 01:49 AM
I have an older 12” craftsman. Added a linkbelt, and new carter tires. It runs smooth enough for what it is. If the pullies wobble then look at getting some Machined ones. They cost a lottle more than the cheap drop cast but will knock down the vibration. A good blade makes a differance.
-- Mike.... West Virginia. "Man is a tool using animal. Without tools he is nothing, with tools he is all.". T Carlyle
View doncutlip's profile
doncutlip
2832 posts in 3792 days
#2 posted 12-30-2011 01:55 AM
You could put a reference edge next to the wheel and rotate it, that would show if you have runout. I have a 14 inch BS and have never got it vibration free, and it does vary by blade width. If it wobbles/vibrates without a blade then that’s probably bad.
-- Don, Royersford, PA
alfonse
#3 posted 01-21-2012 10:10 PM
thanks for all your help i finally got all my parts , all new bearings new tires new shaft and belt and belt pully . i cant beleive anyone would abuse a tool that bad . runs a lot smother now . iam in wood caveing heaven now .when i put the new tires on they went on so tight i didnt glue them ,hope that allright they are rubber.thanks again .
View Bill White's profile
Bill White
5148 posts in 4197 days
#4 posted 01-22-2012 12:34 AM
Good luck. Hope that you’re not beating a dead mule. New b’rings, tires, sheaves (pullys) will give ya a head start. Did ya get a link belt? Get a good blade!!! Don’t EVEN think that any blade over 1/2” will work. I use 1/4” blades for most of my sawing. What’s the HP of the motor? Anything less than 1/2 HP will give ya limited capability.
Bill
-- bill@magraphics.us
