Dust collectors
Forum topic by JollyGreen67 posted 12-28-2011 10:05 PM 1330 views 0 times favorited 11 replies Add to Favorites Watch
View JollyGreen67's profile
JollyGreen67
1663 posts in 2728 days
12-28-2011 10:05 PM
I know I’ve seen blogs, forums, and reviews about HF dust collectors, can’t find them now. What kind of opinions would anyone care to share about the HF 31810 1hp 660cfm vs HF 97869 2hp 1550cfm dust collectors. I looked at all the “big brand” items – expensive! One question – of many – of the HFs, are the impellers metal or plastic? And if plastic – how durable? Do they actually live up the cfm ratings? How much noise do they incur (have to be a lot less than a shop vac)? How does the 97869 seperate the chips? Reason I’m looking at the HFs is – they are on sale, AND, I have a 25% off coupon!
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected !
11 replies so far
View JL7's profile
JL7
8644 posts in 2930 days
#1 posted 12-28-2011 11:07 PM
My Dad has the 2HP HF collector and I am fairly impressed – quieter than my 1-1/2HP Craftsman Pro (which I believe is the same as the Delta).....He added the Thein separator and works better yet. You can usually pick this up for $149 with the coupon in Wood Mag….
Jeff
-- Jeff .... Minnesota, USA
View IrreverentJack's profile
IrreverentJack
727 posts in 2808 days
#2 posted 12-28-2011 11:25 PM
I think an HF DC with Bert's modifications will give you the most bang for your buck. -Jack
JollyGreen67
#3 posted 12-29-2011 04:48 AM
Jeff and Jack – Thanks for the info, and the sale of the HF DC. Too bad you guys don’t get a commission. I also looked at Bert’s modification – that’s the way to go. Now all I have to do is wait until next Monday, 1 Jan, to get my 25% discount. And a big thanks to all the LJs out there who answered Rob and Randy’s similar question.
View RockyTopScott's profile
RockyTopScott
1186 posts in 3443 days
#4 posted 12-29-2011 05:01 AM
HF has a 25% coupon going on….where?
-- “When you want to help people, you tell them the truth. When you want to help yourself, you tell them what they want to hear.” ― Thomas Sowell
JollyGreen67
#5 posted 12-29-2011 05:20 AM
RockyTopScott – I guess every where? I was at my local HF in Albuquerque yesterday, to pick up a 12awg ext cord, and was given a 25% off coupon for anything. Good for one day only, 1 Jan 2012. GO GET ONE! Fact is,
the cashier gave me two!
View brtech's profile
brtech
1028 posts in 2887 days
#6 posted 12-29-2011 06:28 AM
Get the 2hp. But, you need a better filter. The stock 5 micron bag won’t cut it. The right thing to get is the Wynn Engineering pleated filter. .5 micron. Much better. A Thein filter is great.
The impeller on the 2 hp is metal. The separation is okay, but adding the Thein baffle is worth it. Best in a trash can separator, but you can put it inside the ring. The noise is okay. It doesn’t live up to the cfm rating but it has waaay more bang for the buck than the others rated for 2hp.
It has a 5” inlet with a wye to two 4” inlets. A single piece of 10’ x 4” hose works fine. For permanent ducting 5” is hard to find and/or expensive. A 6” main line is a bit much, probably all 4” will work the best. No 90s or T joints, use 45 s and a short piece of straight pip, and wyes. S&D PVC is good. Use blast gates and open one at a time.
JollyGreen67
#7 posted 12-29-2011 05:51 PM
Thanks Bert. Am waiting patiently ‘til Monday.
View Dallas's profile
Dallas
3599 posts in 2452 days
#8 posted 12-29-2011 06:01 PM
Umm, Here in Texas January Oneth is on Sunday.
Maybe you should check where you live.
View b2rtch's profile
b2rtch
4851 posts in 3013 days
#9 posted 12-29-2011 06:02 PM
rosebudjim, If you need help to modify your DC, contact me I shall help you.
In fact this is very easy to do.
In addition I cut a window in the trash can to see the level of the dust inside and to empty it BEFORE I get anything in the plastic bag/filter.
-- Bert
JollyGreen67
#10 posted 12-29-2011 06:51 PM
Dallas – You’re correct, here in New Mexico it is also Sunday – duh on me. My dislexia got the best of me. Can’t hardly wait ‘til SUNDAY !
Bert – I read your explanation, very carefully (remember Monday?). I also printed off the photo of your DC system – looks pretty simple. Have you had any bearing problems with the system horizontal ? I like the horizontal idea – saves space – with a direct route to the seperator.
b2rtch
#11 posted 12-29-2011 06:54 PM
Some people have made this modification long before me.
The question about the bearings comes up again and again, as far as I know no one had bearings problem.
-- Bert
