| Forum topic by TedS | posted 512 days ago | 1838 views | 0 times favorited | 17 replies | ![]() |
512 days ago |
I’m using one-inch thick quarter-sawn oak planks I salvaged from an old office desk to build a new kitchen table. I’ve seen various recommendations for how to finish it once planing and sanding are complete. My goal is to bring out the grain and natural color as much as possible and have a finish that resists moisture and other damage—the top will get a lot of daily use. Any advice would be greatly appreciated. -- Ted, Wisconsin |
17 replies so far
#1 posted 512 days ago |
I would use a clear polyurethane like Minwax Polycrylic. Try some on a piece of scrap. -- Adversity doesn't build character...................it reveals it. |
#2 posted 512 days ago |
Would the clear polyurethane like Minwax Polycrylic pop the grain and ray fleck? |
#3 posted 512 days ago |
A stain will help you pop the grain more than the poly. A basic Golden Oak stain will not change the color very much. You still need the poly for the protection it offers. Do not consider a combination stain and poly. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
#4 posted 512 days ago |
I agree that stain will cause the grain to stand out. What I have done is use an alcohol dye, then polyurathane over it. If you look in my gallery at the tall mission clock, you will see how that turned out. Its white oak with the dye/poly. The panels in the sides are QS white oak plywood so they dont have the grain that the solid wood has on the frame/edges. You can get the dye in many colors and actually mix them to create what you would like…testing it on a test piece of course before applying it. -- Wayne - Plymouth MN |
#5 posted 512 days ago |
Rich’s suggestion is good. Or you could try some boiled linseed oil on a scrap and see if you like how that makes the grain pop. But definitely go with the polyurethane afterwards for its protective characteristics. -- Charlie M. "Woodworking - patience = firewood" |
#6 posted 512 days ago |
I would agree with the polyurethane. I spent a couple of weeks getting a super smooth finish with lots of depth using the poly/boiled linseed oil/thinner followed by wax/oil on my coffee table. My wife spilled water on it and now it has a water stain from the spill. I’m in the process of starting over – this time with polyurethane or polyacrylic. First though I have to sand out the water stain and most of the finish. -- Earl "I'm a pessamist - generally that increases the chance that things will turn out better than expected" |
#7 posted 512 days ago |
Water based poly alone won’t do much for the grain. -- He who dies with the most tools... dies with the emptiest wallet. |
#8 posted 512 days ago |
I use pure tung oil on my dining tables. It’s time consuming, but I put about 10-15 coats on, starting with a tung oil/turpentine mix and gradually end up with pure tung oil. The first coats will need about a day or so between coats and the later may have to go a couple of days between. Tung oil is very water resistant. The white stains you get from water, is caused by water getting under the finish. Water will bead up on the surface, but, as with any finish, if you spill something on it, wipe it off. I renew the finish once a year on my tables with one coat of pure tung oil. No sanding required. If it’s scratched or damaged, its also easily repaired. -- Tim-- http://www.tmuli.com |
#9 posted 511 days ago |
Thanks for all the great advice. Very much appreciate it. Our 1959 ranch has all golden-oak-stained oak trim which is still in good shape so that’s a natural for the new kitchen table. Best vibes from America’s Dairyland. -- Ted, Wisconsin |
#10 posted 511 days ago |
If you want to try an old method. -- Superdav "No matter where you go - there you are." http://chiselandforge.com |
#11 posted 510 days ago |
Interesting idea. Gotta wonder how anyone stumbled upon this method in the first place. Thanks, Ted -- Ted, Wisconsin |
#12 posted 510 days ago |
Ted, be sure to try the vinegar method on some scrap, not your table top. That method is used to ebonize oak, so unless you’re after a gray finish, or have a new sander that you want to put a couple of hours on, I wouldn’t put it on the table top. -- Tim-- http://www.tmuli.com |
#13 posted 510 days ago |
Thanks, Tim. I’m going for a natural look that brings out the exotic grain of the quarter-sawn oak so don’t want to darken the material anymore than necessary. I found a website http://www.woodworkerssource.com/blog/?p=1368 that recommends Deft Danish oil followed by several coats clear Deft lacquer. Seems like a good approach. -- Ted, Wisconsin |
#14 posted 509 days ago |
I like the look of danish oil. It will make the color and grain stand out. Afew coats will be a good finish and protect it from ragular wear. -- Owner of custom millwork shop |
#15 posted 509 days ago |
I’m not seeing any comments on filling the grain. Are you going to build enough coats to flat sand it and get it really smooth? Kindly, Lee -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3552 |
15797 |
Hand Tools
2038 |
Jigs & Fixtures
495 |
Wood & Lumber
2842 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
